Xr6 Turbo 2004,
hey guys,
Just so you know this is an EOI, Dont even want to sell this car. So dont send me offers and swaps for your Vl turbo or your Triple S pulsar. (I dont want it)
2004 xr6t
Vixen red (looks orange in these photos, its not, Crap camera)
160ks,
Auto
Full service history.
MODS!
Tinted windows,
2.5in catback exhuast
APS cold air intake, K&n panel
SCT xcal3 flash tune
All stock parts supplied.
Car was stock standard 2 weeks ago, All mods have taken place very recently (tune was done on friday)
Car is in very good condition,
Engine and drive line is faultless.
Reg and RWC included.
$13,500
  • 1 month later...
Ok guys, Car has a brand new Garrett turbo from an FG xr6t. $2000 latter, plus all new gaskets, Oil screen filter. Oil, coolant.
Car has AMAZING torque now. No lag what so ever!!
Also replaced, 6 genuine coilpacks and Iridium spark plugs
This is a perfect base for someone wanting an unsuspecting 300+kw monster.
  • 3 weeks later...
 Share
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
