Just a question relatin to tint-I took the chaser thru regency yesterday and the tint was too dark so they got me to peel it up enough so it had to be replaced-that way they would
pass it, but I want to know If you can damage the rear window (the lines set in the window to defrost it). If I peel the tint of the rear window is it going to ruin these-?any particular way to do this,or best to get one of the above guys to do it?cheers
https://www.sau.com.au/forums/topic/358194-car-tinting/#findComment-5724535
Auto Perfection hands down! Club sponsor and an all round awesome guy, quality work.
+1 had my tinting done by them and its absolutely awesome. No bubbling etc. Talk to him about getting it through regency and he might be able to help you out there too :D
https://www.sau.com.au/forums/topic/358194-car-tinting/#findComment-5724800
Not making any promises but just dont cut any of the lines with a blade. So get a blade and get a corner started but done use the blade in the middle of the window.
AS long as you dont cut the demister lines then Ive never had any problems
https://www.sau.com.au/forums/topic/358194-car-tinting/#findComment-5725283
I can't tell you who to go to, but i can tell you NOT to go to Auto Perfection.
I unfortunately bought into the last SAU SA group buy, for two cars, the front windows of the stagea and full tint for my Chaser. Both times I was told to get there in the morning before about 10 and car would be ready by around lunch. Both times I did not get the car back until 5 or 5:30 then was palmed off some bullshit excuse that differed wildly from what I was first told, or told again when I called to see how the car was going.
The second time my wife and I spent the majority of the afternoon (4hrs+), sitting in the waiting area, listening to the pig of an owner verbally abuse his receptionist repeatedly, then whenever an angry customer arrived (we counted 5 in the time that we were there, out of about 7 customers total), he would scurry out the back, telling his receptionist that "he wasn't there", to leave her to take the beating. One poor woman who was also waiting on tint and had dropped her car off at around noon, came back just before we were leaving, to see that her car hadn't even made it into the workshop yet.
What's more, I now have a 3-4 inch long scratch on my driver's side window, pin-prick holes on the passenger side tint and the tint looks like it hasn't bonded to the rear windscreen properly. But i absolutely REFUSE to take it anywhere near them and will have nothing to do with them further.
This is my personal experience. Not my friend's friend's friend's (although I have heard those as well). If I had my time again, I would have paid the $30 or so that I saved in the group buy and gone to somewhere like instant windscreens, where they're nice, they do their job in the timeframe they specify ad you get quality work.
Edited by pyro-ns
https://www.sau.com.au/forums/topic/358194-car-tinting/#findComment-5725717
Auto Perfection burnt the f.......k out of my roof lining all the way across my back window when tinting
I could not believe they could do this much damage with a heat gun ,
GO ELSEWHERE !!!!!!!!!!!!!!!!!!!!!!!!!!!! +1
Edited by NISSAN GTR
https://www.sau.com.au/forums/topic/358194-car-tinting/#findComment-5725771
i had to peel a bit off so regency could see it was damaged enough to have to be replaced just so they would let it pass. I peeled the top corner not using a knife just ripped a bit up with my finger and started peeling it off. it peeled off over the line and the bit i peeled off looked like it had a bit of the line on it, I wasnt sure if it was just colour or part of it so i stopped. Guess i should play safe and take it to a tinter unless its definate I wont wreck it. thanks mate
https://www.sau.com.au/forums/topic/358194-car-tinting/#findComment-5725810
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
