MODIFICATIONS:
*266HP AT THE WHEELS
*HKS 2540 BALL BEARING TURBO
*HKS DUMP PIPE
*BOSCH 044 FUEL PUMP
*HKS POLISHED STAINLESS EXHAUST SYSTEM WITH HKS MUFFLER
*APEXi BAR AND PLATE FRONT MOUNTED
*TRUST AIR FILTER
*SERIES 2 REAR END/LIGHTS
*18' RACING BLITZ MAGS (FALKEN ZE326 265 REAR ,235 FRONT)
*TURBOSMART 2 STAGE SWITCH
*WHITE DIALS (ILLUMINATE BLUE/GREEN)
*RAZO TURBO TIMER
*AUTOMETER PILLAR MOUNTED BOOST GUAGE
*DOUBLE DIN STEREO / 12 " KICKER SUB AND AMP -CUSTOM MADE ENCLOSURE
*CUSTOM FRONT BAR AND BODYKIT
*GFB BOV
*SHORT SHIFTER
*JIC HEIGHT ADJUSTABLE SUSPENSION
*NISMO STRUT BRACE
ASKING $27000.
YOU DON'T WANT TO KNOW WHAT IT OWES ME.
REASON FOR SALE--I WANT TO GET A GTR.
CONTACT DETAILS:
RICK HANSEN
0417062253
0749393527
[email protected]
https://www.sau.com.au/forums/topic/3582-266hp-wheels-33-4-door/
sorry for hi jacking your thread.. but were you down the coast recently. I swear I saw your car parked on the gold coast hiway in broadbeach.. or just south of broady..
if it wasnt you there is another 4 door running around that looks very nice :)
I only drag at the strip.Especially in a town that I don't know what the cops are like.Thanks for the compliments.Whats a good price for gtrs down there.I test drove a few while I was there.Mine pulled harder but 4wd is cool.Prices were around $50000
Prices vary soo much its not funny. I was looking at a 91 180sx in a dealer the other day for 19,900... yes it was stock as a rock too... where I could get the same car for around $10,000 private sale.
It seems as if a reasonable price for a GTR now is around 37,000 - 45,000 for something pretty stock.
Guest sir calais
man after seeing that car in real life and have it overtake you several times on the way home for work it makes you want it. Its awesome. If I had the guts to get rid of the VL I'd buy it.... or if I could remeber where I planted that money tree. :D
Hey Rick are you open to offers? I've got a few mates who have seen it on the beach front a few times and might be looking for a new car.
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
