The Plaque on the Turbos State...
14411-06U00 Which is the Nismo 32 Serial Numbers which Correspond to A/R .42/.64 Housing & 560Ps Output.
But these have been measured by Precision Turbos in Wetherill Park to be same as NISMO RS581 GT Le Mans ~640Ps Spec units. (Balancing Markings Still Visible)
Same Spec as HKS2530 & 2860-5 But Bush Bearing not Ball Bearing,
marginally less responsive for street application but for track application very good as they are more forgiving than ball bearing units and also much cheaper to rebuild should the need arise As BB units are basically buy new turbos minus the housings...
Below are specs of Nismo RS581 GT LM & HKS 2530 (2860-5)
Nismo GT Le Mans (14411-RS581)
Compressor Housing T04B
Compressor Wheel T3
Compressor Wheel (mm) 47.2 - 60.1
Compressor Trim 55T
Compressor A/R 0.6
Turbine Housing T25
Turbine Wheel T25
Turbine Wheel (mm) 47.0 -53.8
Turbine Trim CD79
Turbine A/R 0.64
Cut back 15°
Bearings 360°
As pair ~640PS
HKS GT2530 (2860-5)
Compressor Wheel T03
Compressor Wheel (mm) 47.7 - 60.1
Compressor Trim 63T
Compressor A/R 0.6
Turbine Housing T3
Turbine Wheel GT25
Turbine Wheel (mm) 47.0 - 53.8
Turbine Trim 76T
Turbine A/R 0.64
Bearings BB
As pair ~640PS
These will easily do >400KW as can be seen on RB26 Thread with right setup & tune.
Hope that's enough information but here's a few photos.
They are a bit dusty but they are in great condition with no radial (side) play, thrust (forward/back) play, no scraping & no chipped or bent blades.
Can take close up of wheels if needed
Price: $1400 Delivered for Turbos & Braided Lines (I Payed More My Loss Is Your Gain)
Reason For Sale: Never fitted them up, decided to change plans and bought a set of Smaller turbos to suit daily driver focused set up.
(My Selling History Speaks for itself.)
Contact: PM for Mobile Number.
Also have heaps more parts in my Signature.
Edited by krayzie32
  • 4 weeks later...
Price Update:
$1600 for Turbos and HKS Dump Pipes to Suit R32/R33 GTR
Dumps are pictured below:
Will separate dumps for $450
  • 3 weeks later...
^No, as they have different flanges...
T25 (GTR) vs T3 (GTSt)
not to mention exhaust side 5 Bolt (GTR) vs 6 Bolt (GTSt)...
Anyways still have these...
Perfect for a track beast...
  • 1 month later...
Kinda totally forgot about these..
Dumps Back up for Sale...
$1500 for the Lot
Can't get any better than this.
Edited by krayzie32
  • 3 weeks later...
how would the standed rb26 internals handle against these
and are u open to swaps
Standard internals would hold up just as much as they would with HKS 2530's or Garrett 2860-5's
A healthy STD RB26 would hold up fine as long as you don't push them too hard to too long without regular maintenance.
I'd be interested in swaps for a nice fresh pair of Dark coloured Bride/Recaro Seats & Rails to suit R32/R33/R34 GTR.
All other PM's Replied to.
  • 3 weeks later...
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
