DRFT D1 S15 drifter... around the corner from me.
This is it.
These pics were taken immediately around the corner from my apartment.
I don't mean to sound co_cky, but how many of you live around the corner from a D1 driver? This is DRFT D1 driver Akinori "Uchii" Utsumi's DRFT D1 S15 chop-top drifter on a flatbed truck at 9am this morning:
So you're probably thinking, why don't I get expert drift tuition from this guy?
I will, just as soon as I get my 180SX... I kid you not.
Oh, and here's me doing my best "Jash" impression at the Osaka Auto Messe last month... with "Asuka"...
Good son of rajab... look at that tummy...!
Oooooh, don't do that!:woofy:
Asuka is "Rei's" friend... yep, if you know one RQ, you know about 20 of them. Asuka is coming to our school next month for a trial lesson. Can't wait!
You should interview him Rezz!
Good idea... but you should of seen Uchii when I told him I live around the corner from him and walk past his house every day!!! He was embarrassed for sure... I think it's coz he still lives with his parents... :)
Haha, thats awesome, Come to think of it the D1 Round champs only get 300,000 Yen ($3500) and Imamura who was D1 Champ last year only received 1,000,000 Yen ($12,000 AUD)... So I don't blame the poor bugger if he is still at home, that amount of prize money isn't much considering the cost of the amount of modifications that they have in there drift machines, I guess the sponsers pay for it all :D
Better be soon Justin, before the cold disappears :).
Me been away for 2 weeks, hosed the light snow off the car last weekend luckily the snow we get doesn't collect on the road. How good is that 3 degree day temp :D:D:D
We will have to catch up before you leave for Aust, exchange our photos etc.
Certainly is good weather for thirsty turbos :P
We had a big dump of snow here the other day - didn't last long, but I was talking to some elderly japanese gentlemen (70s and 80s) in my eikaiwa class and they both said it was the only time they had ever seen heavy snow in march.
Roll on humid weather I say! still got the frickin' rainy season to go though...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
