Hi Guys,
just wanted to know what is teh difference on the turbos for GTR33??
I was looking at this one below from ebay; http://cgi.ebay.com.au/R33-GTR-Turbos-N1-Steel-Turbine-RB26-R32-R34-changeover-/120487485104?pt=AU_Car_Parts_Accessories&hash=item1c0d9d1eb0
R33 GTR Turbos N1 Steel Turbine RB26 R32 R34
and comparing to the -5 or -7
my aim is to get about 300kW on standard engine, power FC, adj cams and bleed valve....atm it is doing 265kW
help me guys, im confused....reason i want to go with the "R33 GTR Turbos N1 Steel Turbine RB26 R32 R34" is because they are cheap.....
https://www.sau.com.au/forums/topic/358279-turbo-difference/
Mind you to get a set of -9 with actuators you would be looking at $2700 being more than double the $1250.
Sure they might be a bit laggier than stock but I would think they could put down around 280-300rwkw without too much hassle.
I dunno I am curious too hear about these. I have a set of -9's waiting to go in but I was seriously considering these initially.
When could you expect 1 bar boost with these? around 4500-5000 rpm?
Basically -5 response (4500rpm before anything really happens)
With -7 power
Pretty poor IMO when the -7s are on almost 1000rpm sooner
1000rpm less response with 60-80rwkw less… The extra 1500 is worth it. Best value for money modification.
It’s also power delivery in/out of gears as well. Not what it makes on a loaded up dyno run.
Hey Ash, you always seem to know the g-o with forced air induction. I'm currently getting my 31 worked on at Chasers. It's a stock RB30ET using stock intake manifold, getting a new GT-3586, 45mm ext. wastegate, 3" exhaust, running a gtr cooler (not sure exact dimensions but big). I know i'm going to be making good power but what sort of spool time / response / lag do you think I will be looking at?
Cheers,
James
have a look at calaisturbo.com dude, that's pretty much the standard combo over there ;)
been 8years since I've really looked at 30et results.
stock exhaust manifold and cams will be your issues though with that turbo/motor combo. you need a bit of cam to get the ole SOHC working with a 35
Ook, cool, cheers. I didn't pick the turbo as I have no idea.....also getting ecu and fuel upgrades atm......plans to DET in future with 30 bottom end.
Not even sure of the turbo I blew up (bent shaft), people told me it looked like a factory 33gtr. Used to be spooled up @ 2000rpm in 2nd, 2800 in 4th, and pulled quite hard at 14lbs to redline, where possible, within limits of course. So quite punchy, and nice to drive. I'm worried it's gonna lag like a pig atm, but Chasers think that it'll be fine once tuned.
Thanks for your input.
Power vs lag = it'll be laggy with that turbo. No two ways around it regardless of what people tell you.
You can't bolt on a 700hp turbo and expect response :)
If you had some head work, cam, exhaust manifold and a 3.5-4" exhaust you'd make 350-370rwkw and this would obviously offset the lag in that respect. However my stab in the dark will be 300rwkw depending on how much boost can be wound in. Which is what a 3076 would have done :)
See how it goes either way.
Sweet, will do. If all goes to plan, you should see it next Sunday, providing its all together by then. The Haltech Sports 2000 is in and wired up, just stuffing around with cooler, exhaust & dump pipe, then tune. Worried that clutch won't hold up for dyno tune, if so my car wont be there.
Hey mate, did you used to hang around reservoir in the last couple of years. I have seen another orange 33 looks identical from what I remember. Haven't seen the car in over 18months. Not sure what the plates were, but basically, used to 'CR33M' every time I seen it. Coincidence? (havent seen any other orange 33's)
Wasn't me mate. There is some guy up there that has a similar looking car to me. But think he has a top secret kit, no carbon lip spoiler and had a orange bonnet.
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
