motor is a S1 stagea (non neo)
car is a s1 R33 gtst
ok so has anyone done this? if so how did you go about the oil pickup positioning?
the plan was to use my sump and bolt it onto the stag motor, but they aren't co-operating
the pickup is in the wrong spot :/
https://www.sau.com.au/forums/topic/358308-stagea-rb25-into-33gtst/
custom pickup in the base of the pan approx 1-2 inches back from centre....tube exiting the side of the sump to a fitting (-8 or similar), then hose from there to the exhaust side of the pump where you have to remove a welch plug and tap a thread. Put a -8 or similar AN fitting in the side of the pump and join that hose. Tap a thread in the back of the pump where it normally sucks the oil in and put in a flat blocker or welch plug. DO NOT WELD IT or you will distort the pump.
Job done
sorry I forgot you are going the other way. You should be able to just make a custom pickup using 16mm stainless bends and keep it all inside the sump (if you are using the tin sump)
If you are going the other way, the external method is the only way because of the position of the driveshaft through the centre
Just gotta make sure the height of the pickup is ok and not too close to the pan floor, also not too far away. 5-10mm from the entry should be ok.
Also with the added length you may have issues with vibration in the tube so get them to re-attach the other mounting strap that is on the stag pickup. It will strengthen it
so measure the height that the current one sticks out of the block, weld it, keeping bends minimal, attach secondary strap... done...
will post results when done aight
:D
going to try leaving the stagea pickup in it's standard spot and cutting out a hole in the RWD sump's splashguard.
(providing the height of the sump's are the same and not deeper/shallower)
can anyone think of a reason why this could fail?
i'm thinking i might just cut the stagea sump and use that...
i was reading a thread about RB26's into s13's and everyone seems to just cut the 26 sump and use it, as they get the stronger sump and less hastles
as far as I can see this is exactly the same scenario.
gonna ring trent and ask him today as he has already done this on cat's race car
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
