as the title says wanted drift car s13,s14,r32,r33
can be track only
swap for a r34 non turbo auto (coupe) yellow has nismo front bumber, r34 gtt wheels
link
http://www.skylinesaustralia.com/forums/topic/357599-for-sale-r34-coupe-na/page__p__5715762#entry5715762
located in melb
please call or txt me on 0457 245 473
https://www.sau.com.au/forums/topic/358349-wanted-track-drift-car/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
