hi guys
here i have the following parts for sale
garrett gt3076 turbo brand new still in box
CHRA
700177-5018
Compressor Wheel Inducer Size (mm)
54.97
Compressor Wheel Trim
52
Compressor housing
a/r .70
Turbine Wheel Exducer Size (mm)
54.98
Turbine wheel Trim
84
Exhaust housing
.82
internally gated
Brought this to upgrade my rb25 but no longer need it
Asking $1700 ono
Sard 550cc injectors to suit rb25det brand new in box with plugs $600
Nissan z32 computer
Brought this to do a a nistune upgrade on my rb25 but no longer need it. $150
Nismo 2-way lsd diff with 6 bold half shafts
Came out of my s13 silvia was in good condition when i had it in my car $600
S13 side skirts not sure what brand has little crack at the back of one $100
Advanti envy rims there are 17/7's multi fit four stud, 4/100 and 4/114.3 will fit s13 and 4stud lancers
tyres are in ok condition 2 have camber wear $400 ono
180sx rolling shell, no motor or gearbox, missing front bar rear seats and boot lining $$$ make an offer
5-zeigen 2 1/2 inch cat back exhaust so fit s13 with cannon few dents n scrapes $100
Rb25 3" split dump pipe with screamer $150
S13 bonnet perfect condition just needs painting, no dents $200
Set of 4 s13 standard struts with springs, perfect condition $200
Set of 4 s13 standard struts with lowered king springs $300
Unknown oil catch can with hoses, good condition $50
Ca18det manual gearbox cant remember how good it was tho $200
Pick up on the larger items but can post smaller item at buyers expence
I am located in bairnsdale in victoria
If u have any questions or want pictures sms or call me on 0405 548 812 or pm me, would rather a call or txt as i dont use computer all the time
will try upload pics soon.
Cheers jason
https://www.sau.com.au/forums/topic/358356-garrett-gt3076-plus-other-parts/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
