hi guys
here i have the following parts for sale
garrett gt3076 turbo brand new still in box
CHRA
700177-5018
Compressor Wheel Inducer Size (mm)
54.97
Compressor Wheel Trim
52
Compressor housing
a/r .70
Turbine Wheel Exducer Size (mm)
54.98
Turbine wheel Trim
84
Exhaust housing
.82
internally gated
Brought this to upgrade my rb25 but no longer need it
Asking $1700 ono
Sard 550cc injectors to suit rb25det brand new in box with plugs $600
Nissan z32 computer
Brought this to do a a nistune upgrade on my rb25 but no longer need it. $150
Nismo 2-way lsd diff with 6 bold half shafts
Came out of my s13 silvia was in good condition when i had it in my car $600
S13 side skirts not sure what brand has little crack at the back of one $100
Advanti envy rims there are 17/7's multi fit four stud, 4/100 and 4/114.3 will fit s13 and 4stud lancers
tyres are in ok condition 2 have camber wear $400 ono
180sx rolling shell, no motor or gearbox, missing front bar rear seats and boot lining $$$ make an offer
5-zeigen 2 1/2 inch cat back exhaust so fit s13 with cannon few dents n scrapes $100
Rb25 3" split dump pipe with screamer $150
S13 bonnet perfect condition just needs painting, no dents $200
Set of 4 s13 standard struts with springs, perfect condition $200
Set of 4 s13 standard struts with lowered king springs $300
Unknown oil catch can with hoses, good condition $50
Ca18det manual gearbox cant remember how good it was tho $200
Pick up on the larger items but can post smaller item at buyers expence
I am located in bairnsdale in victoria
If u have any questions or want pictures sms or call me on 0405 548 812 or pm me, would rather a call or txt as i dont use computer all the time
will try upload pics soon.
Cheers jason
https://www.sau.com.au/forums/topic/358356-garrett-gt3076-plus-other-parts/
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
