I only said 2J, and besides even IF mine had a 2JZ-GTE it wouldn't be worth 15k. 5spd would blow in no time, along with its crapy 2/1 pot brakes... still rather spend the coin on a decent RZ.
  • Replies 49
All I want is to know what i'n means? you used it more than 3 times in one post so it's clearly not a spelling mistake. never seen that abbreviation before...
also, found the perfect one for you.
http://www.carsales.com.au/all-cars/private/details.aspx?R=9936012&YearFromShort=1637&__Qpb=true&Cr=0&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&keywords=&__N=1216%201246%201247%201252%201282%204294962861%204294962110%20904%201622%201637&SearchAction=N&silo=1011&seot=1&tsrc=allcarhome&__Nne=15&trecs=10&__sid=11EBBF8BEB96
it's in WA AND it comes with a 2JZ.. asking price is $99,000 but surely much easier than buying one allll the way over east. makes me wonder how all those people import cars from even further away than say sydney. places like japan even. they must be nuts.
I did have one problem with your engine transplant idea though. all the JZA80 supras I could find for sale, yes even the ones in WA, all had 2JZ engines already fitted to them?!?! WTF? their owners must have beaten you to it and installed the 2JZ. maybe you could ask one to sell you one without the 2JZ engine in it, and then you can do the transplant?
there is an awesome supra I've seen in japan (not one of the tops eecret built ones) with a nice built RB26 in it making around 750ps, with sequential 6 speed box etc and lots of gear. I actually like it. it would annoy a few folks though. top secret started sticking RB26 into supras cause he 'knew' how to tune the 26 and thought it was god's gift to engine bays. I did like his GT300 inspired 3SGTE powered supra though. that thing was cool.
did you just reveal his 'top secret' :P
Whoever built that car is a wealthy master troll.
Have to say I'd be doing similar things if I had the money to burn.
His name is Smokey and he is no troll !
and Beer Baron, when looking for Rb26 Supras one of the google images links was in your gallery Lol
Edited by Nee-san
Could you put the AWD drivetrain in that too? Sure the soop would weigh quite a bit, but an AWD Supra would be sweet.
This engine does not need internal combustion to operate, pressure from that turbo alone will suffice lol. You just need to tow start it and build the revs up to 10,000 first :P
    • I also understand psi but apparently most things make more sense in kpa oil pressure being one of a few exceptions so im trying to learn ahahahah, I have no idea of the relief spring pressure tbh I thought 110 which is the absolute peak it hits was about right, I was thinking of removing the relief and making sure it is in good condition, I would just replace it but couldn't find a replacement for an n1 pump too easily but I could just be blind.
    • It certainly does make sense that there is just no oil to pick up, but I can go 3 or 4 gears of WOT and have no oil pressure issues too (I have no logs of this unfortunately) and I have a fair amount of oiling mods to try and help only thing I'm missing is a rear head drain which is potentially the most helpful.
    • speaking of the relief spring and noting this is one of those stupid times where I understand imperial (psi) but the graph is in metric (kpa), it looks like the oil pressure is a little low at full noise too, isn't the relief spring 120psi/830kpa?
    • No. All these dirty old Datsuns are shitboxes. Including the GTR.
    • Yeah well I was thinking...there is nothing that happens when you get off the throttle that should cause low oil pressure, its not like clearances suddenly change or and the relief spring would close and in any case the sensor is on the feed side....so more likely there was no oil available to pick up which means all the basic oil control stuff to: 1. keep oil out of the head (restrictors) 2. get it back out of the head when it gets there (external breathers/oil return, drilling out the block and head oil returns) 3. have more oil in the sump to pick up - larger capacity sump 4. have more oil near the pick up - baffles
