Hi,
I have a twin plate clutch on my R33 GTR. It has the R32 GTR Clutch Slave Cylinder fitted to give it the push engagment required for the twin plate.
What is wrong is that the guy who fitted the R32 Clutch Slave Cylinder has lost the factory push arm that leaves the Slave Cylinder and engaces the clutch throw arm.
Does anyone have a spare lying around or know where I can get one? Alternately does anyone know the dimensions, and i'll get on made up?
Thanks heaps.
Hi man
I have used a 5/16 or 3/8 high tens bolt and cut to suit and rounded both ends with grinder to fit the profile at both ends.
you may need to do a couple of bolt at different lengths to get it spot on.
stuart
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
