HI guys,
Im asking this on behalf of a friend. She just recently bought a 99 skyline GT 4 door. The car was running fine when she bought it last month but now have develops what could be described as a shudder.
The car seems to shake when the revs are low and sometimes conks out when idling. Also sems to have lost a bit of power. Any help with this issue would be much appreciated.
Cheers
https://www.sau.com.au/forums/topic/358399-engine-shuddering-need-help/
I had a similar issue when i bought my 99 non turbo, at the lights the engine will shudder but go away whilst driving.......mine went away when i put in some some fuel injector cleaner and put nothing but 98 petrol.
Ill give that a go. Found out that the car was run to nearly empty maybe it could have some sediment gone through the system or just dodgy fuel. Might try to drain the tank.
how did you get on with the injector cleaner?
mine just started doing this also, - ive been thru the whole coil pack problem and this issue feels much different to me - after a long road trip my car now likes to 'shudder' while idling, but it only seems to start doing it after driving for about 10-15 min after it really warms up, you can really feel it sorta thumping the back of the drivers seat thru the exhaust, yet the engine runs perfectly smooth and rev needle doesnt move. engine light has not come on yet. sometimes when its bad enough it will also struggle to accelerate under throttle, but seems to go thru patches in the rev range where its nice and smooth but then sputters.
about 30km before the problem started i had just filled up my tank from the 1/4 mark and wonder if i got sum dirty/old gas???
thanks.
I dont think you guys have a coilpack problem considering there is no engine light that should be on to indicate this, even if the petrol injector cleaner does not work it does not hurt to throw it in....my mechanic does it to all the cars he servies and reckon its helping to a degree.
best to start a process of elimination.......start with the basics (and interesting enough youd be suprised how many problems can be the simplest of things)....but good luck anyway :)
ps carby cleaner is good stuff too......
  • 2 months later...
Well if you're getting idle hunting when not using the accelerator it's your aac valve, theres a tutorial on how to clean it out. Here it is http://www.skylinesaustralia.com/forums/topic/110431-diy-aac-valve-cleaning-idle-reset/page__hl__diy+aac+cleaning
I find on my r33 that because of my faulty cam angle sensor the timing jumps out and the car feels strangely underpowered in some of the rev range but this problem is intermitant. I took my injectors out and had them professionally cleaned, guess it cant hurt to get it done.
The "Check Engine" light won't come on for coil-pack issues.
Steps to fix this problem:
  • Run shell V-Power (My R33 has a Shell Premium sticker on the fuel tanker.. can only assume they want me using shells premium petrol)
  • Run an injector cleaner (wynns spitfire, for instance)
  • Pull each spark plug out and have a geez at it; are they browning badly? YOu may need to change them.
  • If your spark plugs are functioning fine, it could be a coilpack issue. Check over them for small cracks or damage. I've personally covered mine in silicon which has slightly assisted with my misfire issue.
  • Have you washed the cars engine bay recently?
The AAC valve sounds interesting.. I'll have to do a bit of research about this.
Edited by SKITTLES
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
