HI guys,
Im asking this on behalf of a friend. She just recently bought a 99 skyline GT 4 door. The car was running fine when she bought it last month but now have develops what could be described as a shudder.
The car seems to shake when the revs are low and sometimes conks out when idling. Also sems to have lost a bit of power. Any help with this issue would be much appreciated.
Cheers
https://www.sau.com.au/forums/topic/358399-engine-shuddering-need-help/
I had a similar issue when i bought my 99 non turbo, at the lights the engine will shudder but go away whilst driving.......mine went away when i put in some some fuel injector cleaner and put nothing but 98 petrol.
Ill give that a go. Found out that the car was run to nearly empty maybe it could have some sediment gone through the system or just dodgy fuel. Might try to drain the tank.
how did you get on with the injector cleaner?
mine just started doing this also, - ive been thru the whole coil pack problem and this issue feels much different to me - after a long road trip my car now likes to 'shudder' while idling, but it only seems to start doing it after driving for about 10-15 min after it really warms up, you can really feel it sorta thumping the back of the drivers seat thru the exhaust, yet the engine runs perfectly smooth and rev needle doesnt move. engine light has not come on yet. sometimes when its bad enough it will also struggle to accelerate under throttle, but seems to go thru patches in the rev range where its nice and smooth but then sputters.
about 30km before the problem started i had just filled up my tank from the 1/4 mark and wonder if i got sum dirty/old gas???
thanks.
I dont think you guys have a coilpack problem considering there is no engine light that should be on to indicate this, even if the petrol injector cleaner does not work it does not hurt to throw it in....my mechanic does it to all the cars he servies and reckon its helping to a degree.
best to start a process of elimination.......start with the basics (and interesting enough youd be suprised how many problems can be the simplest of things)....but good luck anyway :)
ps carby cleaner is good stuff too......
  • 2 months later...
Well if you're getting idle hunting when not using the accelerator it's your aac valve, theres a tutorial on how to clean it out. Here it is http://www.skylinesaustralia.com/forums/topic/110431-diy-aac-valve-cleaning-idle-reset/page__hl__diy+aac+cleaning
I find on my r33 that because of my faulty cam angle sensor the timing jumps out and the car feels strangely underpowered in some of the rev range but this problem is intermitant. I took my injectors out and had them professionally cleaned, guess it cant hurt to get it done.
The "Check Engine" light won't come on for coil-pack issues.
Steps to fix this problem:
  • Run shell V-Power (My R33 has a Shell Premium sticker on the fuel tanker.. can only assume they want me using shells premium petrol)
  • Run an injector cleaner (wynns spitfire, for instance)
  • Pull each spark plug out and have a geez at it; are they browning badly? YOu may need to change them.
  • If your spark plugs are functioning fine, it could be a coilpack issue. Check over them for small cracks or damage. I've personally covered mine in silicon which has slightly assisted with my misfire issue.
  • Have you washed the cars engine bay recently?
The AAC valve sounds interesting.. I'll have to do a bit of research about this.
Edited by SKITTLES
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
