my car hits 14-15psi at 3000 but drops back to 10-11 at redline. pod, fmic, nice big intake piping, turbo-back exhaust. turboxs bleed too. i'm considering a different actuator, EBC or autospeed boost controller (altho i doubt it would hold it any better?)
  • Replies 89
I tested out my boost holding capabilities last night, it seems to hold 15 pound, but does drop off to 13.5psi or so somewhere high i the revs.
It is hard to watch the boost gauge, tacho and the road at the same time hehe
I will try and get the datalogging going and see if I can get a read out some time this week
Adam
ive already got the details about the hks actuator, sorry i should have posted already/
Hi Dean,
Hope you are well. Pricing information as requested:
HKS Actuator Update Kit R33 GTSt: 11,384 yen
Shipping: 2,500 yen
TOTAL: 13,884 yen AU$170
Notes: The above actuator is rated for use 0.8 ~ 0.9kgf/cm2.
I didnt end up gettin it cos one came available here, yet the person sellin hasnt mad any contact since he posted it for sale. Anyway i have no money atm, so will have to wait a while before i get this.
Cool - that would be nice :)
I think 0.8 - 0.9 kg works out to be about 12-13psi isn't it ??
That's pretty good, and pretty much smack on what I'm looking for. I suppose if you were really keen you could bleed off 1-2psi to get to 1 bar. But at least you would drop boost like I am :D
J
when i get some money ill let u know how it goes.
Does any body have any info on the wastgate actuator for R32 turbo ive heard it doesnt open til 10psi.
Is this true?
Would it fit in place of the r33 item?
Anybody else done this?
HKS one is cheap enough but im not keen on running 12 - 13psi with standard intercooler/turbo. Plus anymore the 10psi and my engine seems to ping on hot days. Gets to over 40 deg there in Horsham.
Hi Munna
Is this true?
**Yes
**Yes
**Yes, many times
**You have a tuning problem, too much ignition advance or too little fuel. I strongly suggest you get it tuned properly.
Hope that helps
Dean: I found that boost drop on the standard turbo was caused by a combination of reduced ignition timing up top (which reduced combustion pressure and exhaust flow) and the turbo being unable to flow any more air because of high back pressure and cylinder back filling at high rpm. The Vg30 exhuast housing with no other mods on the Rb25 turbo held 15psi to redline. I actually locked my wastegate closed and my RB25 turd and it still still didn't hold boost.... hope that helps
Hi Munna
Is this true?
**Yes
**Yes
**Yes, many times
Hope that helps
Thanks Sydney Kid one more thing
where can I get one from?
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
