  • 1 month later...
ive got in a huge arguement with a knowall who knows nothing on another forum regarding coolants, i work in a mechanical repair business specialising in exhausts and radiators, i change coolant every day, use whatver coolant you want, so long as it has anti corrosive properties that dont effect alloy as they pretty much all do anyway so you should be fine. Red or green, it doesnt matter, its just a dye. I cant remember the brand off the top of my head that i use at work but we buy it in big goon sacks in bulk anyway so i doubt it is retailed. We have both red and green and they both contain the same ingrediants, just different dyes. I run this in 2 of my cars and supercheap brand in the other and have never had an issue, neither have any of our customers.
https://www.sau.com.au/forums/topic/358403-radiator-fluids/#findComment-5828648
Any 1/2 decent 'green' coolant is fine IMO.
Since I like to get my radiator system checked (& cleaned if needed) every year, I just use the 'standard life' coolants & don't bother with the extra long life stuff (the 5 year stuff).
https://www.sau.com.au/forums/topic/358403-radiator-fluids/#findComment-5830889
r u joking?
Nope, i only ever used nissan coolant in my gtr. Pulled the motor down a few months ago and had f**k all corrsion in the coolant ports in the block, which is pretty strange for a motor that old.
Also we have problems with xtrails and d40's overheating at work. Mainly because they've used a non genuine coolant or cheap coolant which has started electrolysis in the aloy parts of the cooling system. Look into the radiator and you will see a fine dust like substance all through the coolant. This infact blocks the radiotars slightly and inturn they over heat. Put your multimeter in the coolant and check for stray current and you will always see a reading well over .3v's in these vehicles. These customers have voided all warrarnty in regards to the cooling system of their car because of this.
Not saying it would be the same in a vehicle with a cast iron block, but just gives you an idea of what can happen. Nissan have also released a tech bulletin to all the technicians about this which gives you an indication of how bad it may be.
https://www.sau.com.au/forums/topic/358403-radiator-fluids/#findComment-5831196
Also see that the coolant you use is for engines with cast-iron-block and aluminium heads.
Coolants for 100% aluminium engines are of a different consistency.
In general I would say that you have to stick to green or blue/greenish colours.
(Though this might not be a binding rule ...)
Basically there are 2 types of coolant:
Silicate based (green/blue)
Non silicate based (red/purple)
Here's the one I use:
http://www.commaoil.com/productsguide/view/6/353
https://www.sau.com.au/forums/topic/358403-radiator-fluids/#findComment-5838809
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
