Hey guys heres the go i have a r33 s1
im parting it out it has a rb25det (auto) running stock boost and never had beeen modded in any way
the engine comes with all running gear but turbo will be sold sepretly
and has cutrrently 128xxx car was not the engine is running so you can come down and have a look and i can even take you for a drive in it
this is an awsome cahnce as you dont normally get to buy a engine and see it run preiously
im wanting 1800 for the rb25det
looking for 350 for the auto gearbox
all component running awsome no smoke or anything like that as noted its STOCK and you can clearly see its never been moded
you can call or email me if you want any information
[email protected] or 0430106414 ( best times to call at after or before std working hours ) or text within 9-5
I will be parting the whole car but i want to sell the engine first and it gives you an opertunity to try before you buy
this has been advitised in many places so act on this fast
https://www.sau.com.au/forums/topic/358407-rb25det-running-motor/
  • 3 weeks later...
price drop 1700 for engine and i was wrong in fact it only has 120.000 and timing belt and pump looks like it has been changed so it HAS done its 100.000 service
engine is now out of the car but a compression test was done before i pull it out and there was no difference between cylinders
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
