Hey guys heres the go i have a r33 s1
im parting it out it has a rb25det (auto) running stock boost and never had beeen modded in any way
the engine comes with all running gear but turbo will be sold sepretly
and has cutrrently 128xxx car was not the engine is running so you can come down and have a look and i can even take you for a drive in it
this is an awsome cahnce as you dont normally get to buy a engine and see it run preiously
im wanting 1800 for the rb25det
looking for 350 for the auto gearbox
all component running awsome no smoke or anything like that as noted its STOCK and you can clearly see its never been moded
you can call or email me if you want any information
[email protected] or 0430106414 ( best times to call at after or before std working hours ) or text within 9-5
I will be parting the whole car but i want to sell the engine first and it gives you an opertunity to try before you buy
this has been advitised in many places so act on this fast
https://www.sau.com.au/forums/topic/358407-rb25det-running-motor/
  • 3 weeks later...
price drop 1700 for engine and i was wrong in fact it only has 120.000 and timing belt and pump looks like it has been changed so it HAS done its 100.000 service
engine is now out of the car but a compression test was done before i pull it out and there was no difference between cylinders
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
