  • Replies 57
Looks good John, what the best place to get that gold foil heat shielding?
Bonnet scoops right there near ram pods.
Gold heat shield stuff from Summmit Racing in USA.
The new VQ30DETT motor compared to the old VG30DETT.
The new motor is running less boost and is on e70 while the VG is running more boost and octane booster
UAS has also recently begun using Computational Fluid Dynamics (CFD) software to aid us in designing elements of our aerodynamics package.
Unforunately time and cost constraints make a true to life simulation a difficut task to achieve, as ideally every component down to the smallest washer should be modeled into the software and then animated to garner accurate results.
STANDARD CAR
FULL CAR SIMULATION
The above two videos show the flow trajectories over the UAS Zed and a standard 300ZX respectively. Though the models are rough they are enough to indicate significant changes in aerodynamic downforce and drag. The figures in the above simulations showed the UAS Zed generated five times more downforce than the standard 300ZX at 200km/h.
To give the exact measurements that is an increase from approximately 50kg to almost 280kg. Drag also increased but only by a factor of two with the standard car measuring 100kg of downforce to the UAS car's 230kg.
The UAS rear wing is a fantastic example of how we use the software to aid our design despite our time constraints. By focusing on a small area in isolation, we can more clearly judge how changes will impact our drag and downforce characteristics.
REAR WING
In this instance it was found that adding a 15mm gurney strip to the larger lower rear wing increased the overall downforce by a significant amount ( ≈ 11%). This produces an extra 14kg of effective weight on the rear at 200kph, with only ≈3% increase in total rear wing drag.
We have also been able to generate numerical data using the program. Doing so allowed us to find a number of interesting results.
On straights, the wear wing of the UAS Zed has a tendancy to flex under the downforce load. This change in area has an impact on the overall downforce of the wing.
Using CFD analysis we were able to simulate a number of different instances. We simulated a straight wing, one with the top wing flexing to touch the lower and an instance of both flexing to the same degree. We did this at both 200km/h and 100km/h simulating a worst case scenario through high and low speed corners.
As can be seen from the tabulated data this flexing causes a drastic change in the dynamics of the wing. Both downforce and drag are significantly reduced as the wing starts to bend.
On straights this is beneficial as it has the same effect as the adjustable rear wing systems used in the 2011 formula 1 season, if to a lesser degree, reducing drag so we can achieve a higher top speed.
In low speed areas it is slightly more detrimental, however it should be noted that at these speeds overall downforce is significantly lower and as such flex is reduced causing a corresponding reduction in overall downforce lost.
my take on it is that the red line is the new motor given the red line is less boost. if its the red line it comes on earlier and stronger but doesnt have the top end in it just yet.
its a good signe for an undeveloped engine so far.
Yes, the sudden drop was the wheels spinning on the dyno, too much negative camber with old road tyres and 18inch wheels with no side wall.
  • 3 weeks later...
UPDATE
Dry sump tank, Oil system now carries 15 litres of oil. Also electric powersteering pump mounted left rear in the car inside this custom box.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
