I'm getting excited about mine just seeing your results! hopefully nothing goes wrong with mine! (fingers crossed)
Yeah i was surprised at the result to be honest!
ON EDGE - Yeah its just pump E-flex
Good work matt car sounds crazy on the dyno i was at JEM I heard it on the dyno.
Thanks Bobby! So glad it is finally with them! They have been amazing and the results are nothing short of impressive :D
Well done Matt, that is an awesome outcome. Makes all the sweat and tears worth it when you get a figure like that.
You must take me for a spin at Marulan, I'm not asking, I'm telling you!! Hahahaha ;)
Spin i can handle, straight line.... Maybe not so much :P
Bet you are counting down until you can pick it up
You have no idea... Although I am stuck with work commitments at the moment so as soon as I can I'll go get it, can't wait to thank Adam and the boys for what they have achieved... So far :P
I said it before and I'll say it again nice result and nice sounding car
If that was mine though I be wanting to get another 17hp out of it just so it makes an even 500
Haha thanks mate.... It sounds alright :yes:
Nope, the turbo was at its limit, pushing it harder just makes things unsafe, the tune revolved around reliability hence why i went to JEM :)
Ill play with it is for a while then consider a 3082 down the track, lets see what Kurtis comes up with first ;) no pressure champ lol
Haha thanks none at all. We all know that if i finished First you would be trying to bet me ; )
The car goal is response if I get my power goal its just icing on the cake
That turbo you have should be an animal... It'll give a good comparison between the 2 setups... Although the exhausts would be good If we had the same... You'll get your goal, I'm confident ;)
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
