There's none anywhere near me.
Looked into WMI setups then? Its why i got the flex fuel setup with JEM as i knew E85 wouldn't always be an option.........
Your car is way too quiet man :P
yeah i agree its all engine, need some more exhaust angryness... if thats a word..
That is the whole aim of the build, stealth :ph34r:
And Martin i am surprised i didnt hear your car from over here while you were at powercruise lol
Its all gate and turbo whistle :laugh: not engine haha
Anyway, got a cruise coming up and cant wait for the damn plate to arrive so have cleaned it up a little and put it back in for now -
This is the fork and new bearing assembled with the graphite powder as instructed :D
Only because you weren't listening hard enough, not because I wasn't making enough noise :laugh:
Gearbox looks good man, nasty bit is out of sight out of mind! :P
Haha i heard LOTS of pigeons ;) I am going to blank the BOV just for Nats and Powerplay just for you :P
Yeah it cleaned up OK, still not happy with it and will remove the box and replace the thing when i get a chance, for now i am just over the car so i better get it back running so i can fall in love with it all over again!
This is a feeling I am familiar with!
Cars appear quieter in most vids. Im sure it is alot louder in the flesh.
Haha I know I know, I'm just giving Mat shit because our cars are so similar :laugh:
Haha Benji you havent really heard it yet :P
Yeah Martin, you knew that feeling for TOO long, why cant both our cars run right for a change lol
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
