nice footage and good to see you beating some awd cars too :P
Haha yeah i got knocked off by one right at the end of the day! But ill be back for more :D
haha damn. its a nice small setup but looks like a lot of fun. planning on any other track days anytime soon?
Yeah quite a few.... Ill post up details soon! Ill upload some more skid vids etc soon......
Cool :)
I've just had a Nismo 1.5way fitted and I'm planning to get over to a wet skid pan day or two and maybe a couple of driftmob days or something like that. Keen to catch up if you're likely to be at anything like that?
Cool :)
Yep for sure :) You will love that diff!! :yes: It is the same as what i run!
Already do :3 ... how long did you run in for? I had it fitted last Thursday and I've done about 350kms so far . Was thinking I'd do 500 before doing anything silly and then change oil at 1000?
1st run of the day to get to know the track -
dam that turbo is good, feel like selling my gtx to get some more whistling happening lol...
nice small track, looks like you could do with a long straight to open it right up
Mine was rebuilt and then run straight on the dyno, after that we did the normal bed in procedure etc..... It has done about 3000kms since the build!
Hey GeeTeeTee I have seen a white GTT like yours in Parramatta a few times recently, not you??
Not me mate, you would know if it was mine :P
Haha yeah i must admit i do like it! I was so close to changing it but with the power it has and the sounds i will just enjoy it for what it is! They are extending the track soon i believe :yes:
Awesome. Might make some of those sounds my new ringtone. :D
Haha nice! Shame i couldnt run the screamer at the event, but it would have echo'd nicely down that hill for all the nearby horses!
man you say thats plumbed back? shit man. sounds orgasmic around 0:32 when the car is close to the cam.
Gate is plumbed back in the videos yes..... The sounds is all induction etc :D
OK guys, after a very LONG day on Friday we have finally nailed the issue that has been causing me grief for quite a while, more info to come on this soon.... For now, i will just put up some thrash footage from Powercruise, it was wet, slippery and pretty useless, but still had fun and cracked gate on every car i could find -
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
