what a bucket! :P
Sonofa...... :rant:
Lolz...
Actually the bucket will be getting a bit of a detail today, apart from the paint peeling of the farken bootlid it should look smick again :w00t:
Carmen has ordered these, they are much better than the old stock seats that are now pretty squished due to my fat ass being in them.... They are GTR style and ADR approved so should be good enough for now!
Ahh I got these seats
Good luck with the rails.
I got bought 2nd hand Bride ones for a GTT. Still had to be modified to fit the seat on
Oh shit really? What model rails did you go with? Any advice will be handy :yes:
You still run them in the car? If so, pics?
Still in the car :)
The rails I brought off the forum:
http://www.skylinesaustralia.com/forums/topic/410569-nsw-r34-gtt-bride-rails-head-light-stock-turbo/#entry6558593
The rails bolt up to the chasis fine. Just the bolts in the rails don't line up with the holes under the chair
i have a set of rails you can test fit if you want?? altho im not sure in the difference in bolt between 33/34 to the floor pan?
Edited by Frosty
Still in the car :)
Pain in the ass
Yeah 34 floor pan is different! They didnt want to make it easy on us!
Plus the 33 needs to be watertight for the ocean :ph34r:
Still in the car :)
Lololol fkn Kurtis..... Ill slap him for selling you the rails and not selling em to me :P
how much out are they over the 32/33? i have a pair of rails that im going to get rid off. Brand spankers
Not sure, what are the ones you have?
i have a bride and a pair of custom made (from NZ) which are brand new! only test fitted to car but cant remember the name for the life of me
Be interesting too see just how different they are. If you can, post a pic of the mounting points and ill compare to the car to see if there is any similarity?
i got a pic of the bride and the custom..what your number? ill sext u the pics
Sext me up!
0434 353 29 Twwwwwwwwoooooooooooooooooooooooo!
Here is the guy that sells the seat mounts:
http://www.ebay.com.au/itm/Recaro-Sparco-MOMO-Bride-seat-mount-Nissan-Skyline-/130277287431?pt=Race_Car_Parts&hash=item1e5521a607&_uhb=1
If the seats you purchase have sliders, it bolts to this which then bolts to the floor. Measure the distance between the bolt holes on the sliders and email the seller and see if they match the holes on the mounts (they should as most are a common measurement).
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
