94633b22-e227-4160-89e8-fbd24d1688c2_zps
23e260f9-508f-43bf-a2de-646418b34068_zps
Fark it needs a good clean! Also need to sort out some heat sheilds on the hot side as there is some meltage happening on a few things :blink:
34GTR front end is awesome!
Certainly look tough and love the fact the front guards accomodate such large rims..... I considered it a while back but it hard to do to a GTT and do it right, you really have to do the rear guards etc to make it looked balance and its big $$$, ill just stick with what i have and make it work the best i can :D
Tractor is out of place in those pics.
Suppose they used it to tow all those broken cars out to the carpark?
Haha that is one tractor i am NOT picking on, it has way more bragging rights and power than ill ever have :P
Oh no picks of my blue beast that was on the hoist. Looking good.
And yes you definitely need to sort some sort of heat sheild before SMSP :P
Lol i dont want to have everyone looking at your beast and not mine :P
Yeah i guess it hasnt been punished for prolonged periods other than the dyno so will see how it hold up with the heat i guess!
Sort it out.
You will melt shit and be put out of the track day otherwise- take it from my experience. Have a look right round teh hot side on the chassis, and cover any loom, pipes, harness, P/S and whatever else you don't want to toast. Mine melted cops tail conduit stuff straight off, started toasting the wiring loom, and I got a misfire. That was with a Beanie on the turbz. High mounts throw heat big time.
Sort it out.
What did you use to cover all your looms etc?
Mine has melted all the plastic hose connectors and black sheathing already! You know, coz racecar!
Dunno - haven't sorted it yet.
At the track Eric put a redbull can over the loom, no shit. Sorted it for the day.
I have a sheet of aluminiumised fibreglassy stuff- thats what I'll probably use, wrap it up. I don't want to cut up one of those nice slip on hose protectors.
This is what I did, works fine.
Would have used some sheet, but I had to buy half a meter of the sleeve to do my 10cm turbo oil return pipe, so I had plenty left over. Just sliced it in half, wrapped up my cables, and cable tied it together. No problems thus far, though I don't have a high mount...
Hmmm well another thing on the To Do list!
Is there any black heat shield crap i can cut up and use to stay with the whole stealth theme?
I know there are a couple of things that need wrapping!
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
