34Geeteetee Daily / Track Project
Oh Nummy. :P
I want me some 33 GTR rims.
Yeah they are just as hard to find! I wasn't going to get a set of track rims just yet as i didn't exactly have the cash to spend BUT these came up at the right price so i had to break the bank :laugh:
How heavy are they per rim?
Compared to the cast XT7's i would say they would be light... The 4 parcels coming have a combined weight of 36kg including the packing materials...
Sure you don't want some SE37's?
Nope, have always wanted a set of black 34GTR rims so now all i gotta do is work out how to clean them up and paint them :D
Tow Car Updates...
The poor cruiser was getting a bit neglected so now it has had full service, big exhaust put back on and some new suspension bushes.... We also decided to replace the floor in the back so we could run Carmens new toy (Weaco 40L fridge)... We are generally useless when it comes to renovating or building anything but we worked OK on this one lol
1148850_616186861791569_1374010907148226
80L of E85 works wonders -
1609807_616186871791568_4775365474188781
We plugged all the holes from the old seat brackets etc -
10150768_616186888458233_326895602340930
10153283_616186918458230_216356620272614
1011802_616186958458226_8746123904220687
10173622_616186938458228_146790096261217
We still need to do some finishing touches and get the fridge bolted down properly etc BUT for all the upcoming track days we will now be sorted! Everytime we go to a day out we find something we can do to make our day better ;)
But...by putting a fridge in there there is less room for tyres!! :P
Cruiser has a big ass roof cage, trailer has about 4ft of spare room... I think we got it covered ;)
Oh and YES in the pictures i was using the 34GTR rims as a work bench for cutting the floor :whistling:
Atleast we know that they are strong haha!
Are you gonna paint them black, Mat? They seem to be in excellent condition as it is...
You going with 275/35's?
Lol yep!
I love the black look and WANT to paint them but i am not sure as yet... That photo makes them look pretty mint but the far one does actually have some rash... Im not sure yet but would hate to break the black/white theme! I see black ones and do like the look of them, would love to change the GTR badge to something else too but not sure if that is possible without too much hassle...
And no, either 255/35 or 265/35 (Leaning towards 265 at this stage)...
The 275 is too tall and puts the speedo out etc....
Plastidip?
Lol yep!
Ah I see haha. I have a feeling they'll be black soon..
As for the GTR badging, Im in the same situation. I found a ebay seller who has circle Nismo badges in any diameter you want. But they dont even look genuine. Was going to surgery them onto the centre caps if possible. Or just get another set of centre caps and hack the gtr badge off...
Plastidip?
I honestly think this is the best option for now! That way it is cheap but also reversible if needed! I haven't attempted it before but i think Carmen is keen to have a crack at it!
:P
Hmmm these centre caps are too clean to mess with! I know places like StreetFX will make stickers and stuff that would cover the spot nicely but i dont want to ruin the caps! I think i might give Matts idea a crack and see how they look...
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
