ooooo dem brakes :wub:
too bad we will never gate cruise together :(
I came too late, well the missus likes me late so that's ok too hahaha
:rofl:
Love those vids, the thing is bullet proof!!
Thanks mate, not bullet proof by any means but it has been good!
What blows my mind is how this engine hasn't gone bang yet...
Well tuned, well maintained... Doesnt mean it wont go but certainly helps!
So now that its a track car I wonder if a HTA35 is on the horizon :ph34r:
It will be an Forced Performance unit if i do, but not the HTA :P
BUT that is not in the budget anytime soon thats for sure, it will just be to run 400kw with lower boost levels to keep heat down, the additional lag will be painful compared to what i have now but if it means saving the engine for longer then i can handle that.
fatz is doing that for you. build thread that way ->
Yeah but Fatz put a cage into his car, and not can't fit in the thing. :whistling:
haha but seriously.....
I am NOT aiming for big horsepower or a time attack machine, i am just aiming for an all rounder that is OK on the track and the street too...
Cheers
Matt
How things have changed ^^^^ :yes:
Lol Fatz aint the only one that doesnt fit...
And yep i only read that the other day and laughed! But its not big horsepower yet and not time attack spec :P So i was kind of right!
^^ :rofl2:
I smell Jelly... :laugh:
Always with the Next Level Mat. :woot: en Love your work Matey.
Team Logo is Awesome but needs more Horses. ;)
  • Like 1
Maybe this neo got forgies or something in Japan before it came here lol... :P its proper angry , should take my username, mine should be just mildlyAngryRB... :wacko:hahaha
Edited by AngryRB
Hahaha still makes me laugh! Good times... Cant believe that will be 3 years ago soon :O
Nope, just a good tuna, good fuel and good times...
Nah I enjoy rebuilding rather than driving.
You are a sick man!
  • 1 month later...
Updated pic on Wootten Racing FB page -
https://www.facebook.com/Woottenracing/photos/a.819477888122136.1073741829.817653311637927/850527885017136/?type=1&theater
After this week we will start releasing all the updates online, it has gone through a LOT of work over the past couple of weeks.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
