When it was ready to come home for final prep prior to the panel shop we found the trailer no longer suited the car, so took to it with an angle grinder... Keen eyes will notice the front bar and spare wheel on the trailer are now missing to get the thing to fit on... We will re-assess the trailer situation once its all complete!
  • Like 1
This brings us up to date with the current progress, things are all happening VERY fast now and the car is taking shape... In the next few weeks you will likely see images of the finished product, after those the car will be re-wired, suspension modified and aligned and then its time to test...
Unloading is not so fun anymore -
Thanks to Brians Race Ramps it wasnt too painful...
  • Like 1
The car is now underway -
11755237_389579074578985_511605816879891
11223898_390192691184290_556477352224918
You can keep an eye on FB for updates on Vacy Smash Repairs FB page, give them a like and you will be the first to see...
  • Like 1
The front end looks F-ing amazing. Can't wait to see this thing.
Have those brakes been in your updates yet?
Pretty happy with it!
Ummm i thought they had, hence why i didnt post anything... Ill look back now!
Edit - There is an image here of them fitted - http://www.sau.com.au/forums/topic/358438-34geeteetee-daily-track-project/page-102
But no official update on them.
  • Like 1
Had a look and realised most of the photos from the Brakes, bodywork, underbody etc are not on this PC... But here are a couple of the brake setup from my old phone...
So the kit is the Alcon 365mm Motorsport kit from Brakes Direct, not to be confused with the street spec kits they advertise, the calliper and pads are completely different -
Ditched the old backing plates to make them fit, will run a brake ducting setup later -
Rotor size comparison -
And the finished product all fitted and bled -
11065909_821195521283706_456016235622054
The newer pics will be put on FB, but ill keep this build thread for the technical aspects and DIY images etc...
Any questions, advice or just general discussion can be kept here too! If it benefits other members then its a bonus!
My god - this beast looks amazing!!
Well done mate.
Thanks mate, really looking forward to the next few weeks as the car evolves!
Mocking up panels was one thing, but seeing them being moulded to the car and taking shape is SO much better!
11752614_392287624308130_320227999871079
  • Like 2
Man good job in that interior there. Ill have to do that at some point and im not looking forward to it.
The amount of hours grinding away body glue and crap is amazing, i spent ages on it!
Its going to look good once done, i guess nobody will appreciate the man hours involved until they attempt it themselves, i know i didnt lol
  • Like 1
HMM call me sherlock.
What colour you painting it?
Just the original white...
Call me Mr Original... lol
I plan on keeping the whole car looking plain as a GTT/R should look.
I will be keeping stickers/logos to a minimum, however the companies that have supported me so far will also have a say in this.
Apart from the roll cage..... And all the body work.... :nyaanyaa:
Since it's full stripped you should put the GTR driveline in it... Just sayin.
I just had my dad remove the sound deadning out of mine as a little project. I think it took about 18hrs spread across 3 days of -5c. Not looking forward to rubbing it back. Yours looks way nicer inside and will look mint with a fresh coat of paint!!
I would have just built a GTR if i wanted that, i wanted RWD and something a little different...
I love driving the rwd GTT but also always preferred the GTR look... So figured why not have both!
It is not a nice job!
I found the glue was the worst part, i guess as they know it will be covered in carpet etc that they just dont car what it looks like but they managed to get it everywhere and it is really stubborn when you try to remove it! I went through quite a few wire wheels...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
