Not much achieved on the weekend, resprayed the radiator air deflector as it was flaking..... Replaced some dodgy bolts with nicer stainless items and cleaned up the 2 front A/C brackets, so much to do.........
The fuel cooler is setup from the return line to the cooler then to the surge tank.
Ahh ok cool, the same way i've done it then.
Is this the 'best' location for it?
Have any of you guys got a temp sensor in your fuel system somewhere? If so, where?
I'm putting one in mine, my idea was to have it in the return line just before the fuel cooler.
No temp sensor in mine at this stage, however i would love to be able to monitor it....
And yes i believe the location is the only spot for it, it is setup similar to the Z tune i think :)
I would put the sensor just before the fuel rail so you know what temperature the fuel is when it gets to the engine. Knowing what it is pre-cooler doesn't help much?
My reason for putting the temp sensor post fuel reg, in between the fuel cooler is this should theoretically be the hottest part of the fuel system?
I would imagine so, either location is still going to give you an indication if the fuel temps are rising.... I still find my surge tank getting hot which i dont think is normal, however everything is running optimal so i guess it is?
One thing i did learn is that the fuel cooler has ruined my normal jacking up procedure, if i jack the back first it makes the front too low, now if i jack the front first i get this -
LOL and yes that is a snap on super low jack already!
All good, will just have to change the way i do it!
And i broke another POS ISC arm in the rear, they flog out or break in no time! Garbage! So i replaced it with more cheap stuff for now until i can afford to do it properly -
GKTech make billet ones, no welds ;)
This will need to be my next purchase i think! I have now replaced the shitty ISC front caster rods with GKTECH arms and the car feels so much better! And they are so light too!
How is the tank plumbed from top to bottom?
There are 4x hoses that connect to the surge tank. All should be at different heights. But some tank are different.
Eg theres two ways to dot it.
From top to bottom;
1.
- Return to main tank
- Return from fuel rail
- Feed from main tank lift pump
- Feed to main pressure pump(s)
2.
Which way is yours done?
The 1st option heats the fuel as the surge tank has to be pressurised to return fuel to the main tank. The main pressure pump and the lift pump have to work harder to fully fill the surge tank allowing fuel to flow out of the top fitting back to the main tank.
You want a small air gap at the top of the surge tank with the return line back to the main tank jn between the return from the rail and the lift pump inlet.
If that makes sense?
I just double checked so i didnt get it completely wrong :P
Fuel tank to surge tank, feeds twin 044s to twin lines to each side of rail, center of rail returning via fuel reg to return line to surge tank over flow to fuel cooler into fuel tank, tank feeds surge.
Loving the build mate. Engine bay looks clean and stealthy...
Thanks mate! Makes it well worth it when not only do i get to enjoy the car BUT i get people appreciating the hard work and money etc that goes into such a build ;)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
