what a bucket! :P
Sonofa...... :rant:
Lolz...
Actually the bucket will be getting a bit of a detail today, apart from the paint peeling of the farken bootlid it should look smick again :w00t:
Carmen has ordered these, they are much better than the old stock seats that are now pretty squished due to my fat ass being in them.... They are GTR style and ADR approved so should be good enough for now!
Ahh I got these seats
Good luck with the rails.
I got bought 2nd hand Bride ones for a GTT. Still had to be modified to fit the seat on
Oh shit really? What model rails did you go with? Any advice will be handy :yes:
You still run them in the car? If so, pics?
Still in the car :)
The rails I brought off the forum:
http://www.skylinesaustralia.com/forums/topic/410569-nsw-r34-gtt-bride-rails-head-light-stock-turbo/#entry6558593
The rails bolt up to the chasis fine. Just the bolts in the rails don't line up with the holes under the chair
i have a set of rails you can test fit if you want?? altho im not sure in the difference in bolt between 33/34 to the floor pan?
Edited by Frosty
Still in the car :)
Pain in the ass
Yeah 34 floor pan is different! They didnt want to make it easy on us!
Plus the 33 needs to be watertight for the ocean :ph34r:
Still in the car :)
Lololol fkn Kurtis..... Ill slap him for selling you the rails and not selling em to me :P
how much out are they over the 32/33? i have a pair of rails that im going to get rid off. Brand spankers
Not sure, what are the ones you have?
i have a bride and a pair of custom made (from NZ) which are brand new! only test fitted to car but cant remember the name for the life of me
Be interesting too see just how different they are. If you can, post a pic of the mounting points and ill compare to the car to see if there is any similarity?
i got a pic of the bride and the custom..what your number? ill sext u the pics
Sext me up!
0434 353 29 Twwwwwwwwoooooooooooooooooooooooo!
Here is the guy that sells the seat mounts:
http://www.ebay.com.au/itm/Recaro-Sparco-MOMO-Bride-seat-mount-Nissan-Skyline-/130277287431?pt=Race_Car_Parts&hash=item1e5521a607&_uhb=1
If the seats you purchase have sliders, it bolts to this which then bolts to the floor. Measure the distance between the bolt holes on the sliders and email the seller and see if they match the holes on the mounts (they should as most are a common measurement).
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
