you mean you need one of these? ($210)
http://justjap.com/store/product.php?productid=18588
Vent holes/grill in the valley cover that allow air to flow can prevent the coils from cracking and the loom from going brittle.
That is exactly what i mean! You sir are a legend :thumbsup: you have saved me having to look any further :D
And yes i have removed the cover for now, vented sounds like the go... I still need to retain it to cover the coils and prevent the COZ RACECAR look as i am doing my best to stick with the stealth theme, i have seen the carbon vented items but these are of no interest.... I want something plain as always!
Loom will arrive tomorrow! Thanks Terry, appreciate the link!
No worries, btw I always chuckle when you write stealth with that shinny high mount ;)
Compare it to the 3 engine bays on the last page, its stealth enough :P
Went for a ride in this beast on sunday.
What a weapon. AWESOME street/track setup. I'd go as far to say it is the ultimate/perfect setup.
No Lag, Quiet idle/cruise, mental when the foot is down. Handling and brakes are great for the street. Love it. Well done Mat and the crew at Just Engine Management for a well sorted package.
Haha thanks Buddy, was good to catch up finally ;)
Hopefully once your weapon is ready we can go run amok more often like old time :yes: just much louder and faster now :P
why not buy a standard and add some vents to it yourself?
Also possible.... Can drill breather holes without any hassle, just the original plastic one looks pretty shit so was going to try pretty it up a bit :P The engine bay looks good but that cover always lets it down as no matter how many times you clean it or coat it black it just keeps ending up the faded plastic colour due to the heat i guess!
so prep it then coat it enamel! solved!
This sounds like it requires effort :/
Well actually it is off the car for a while so i should pull my finger out and do it haha
scotch brite it first then prep it with a few coats of under coat, then black enamel. Never fade again.
obviously cut it up and make it look cool before hand
Cost me $30 to get to work today.
If it doesn't get sorted tonight using ECU talk.
Then I am screwed! Been looking at some nice 34's
You mean mine? :P
Oh, and Just Jap dont muck around -
It was a GREAT catchup. Shame it couldnt have been longer. Im back late september. for two weeks (although one of those weeks I am in NZ), better catchup then?
Yeah, my nugget wont be ready for many months yet. Will be lucky to be end of year at this stage for run-in. But YES, we need to run amok again.
Im jealous, you seriously have the PERFECT streeter. What a weapon.
Edited by Tonba
Yours will be the same once its all setup and running! Will just be a bit more extreme in some ways :P
Yep, late September should be OK, we are away a bit and then October/November we are flat out!
It makes me smile everytime i drive it, thats all that matters too me man! If other people enjoy it then that is just a bonus haha
race your "perfect street" for slips? :P
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
