One thing i am happy to report is that the Tow Rig was awesome! This was the first chance we had to test it out... We were worried the 35s may cause an issue and a few other things but it was faultless, we hooked up the hire trailer which looks like crap but tows amazing, was SO easy to load and unload too being a tilt trailer, basically drove out of the driveway and pulled the car around town to check it out, was really good... Plenty of torque and nice and stable, only time it felt a bit sketchy was hitting standing water on the highway when it was pissing down rain but even then i dropped back to 90 and it was stable az.....
602103_545408595528699_859648326_n_zps64
The cruiser wasnt just the tow rig on the track day, i ended up getting stuck with double duties and had to be the recovery vehicle as well... Not ideal when you are trying to enjoy a track day but what can you do, at least the first lap on the track was in a turbo vehicle lol -
Oh and another interesting thing, i had been complaining about traction issues.... The wheel alignment showed i had 2.2 deg neg camber in the rear so we dialled that out and it was MUCH better... You can see the rear wheels standing upright now! Amazing what a difference it made!
Looking good bro!
Why did the cruiser have to double as a recovery vehicle?
Not sure, SMSP didnt want to use the fire truck as a recovery vehicle i guess which is odd as it had the 2 tow straps already fitted too it :/ anyway, no big deal... Just know to plan ahead for the next one so i dont have to do it! In saying that it went out on track twice as the guys were all really well behaved and mostly recovered themselves!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
