Yep, I'm booked in to both. DO IT!
FYI: Had to take a spot in the beginner group for the one in Jan. Should be ok though with a lot less cars than the "advanced" group. Double quotes on the advanced because I saw the vid of the M5 that was out there...
Ill be watching those vids shortly so i assume ill have a better understanding of what you mean :P
I saw Alexs vid and it looked awesome!
Will try book both once i know the car will be 100% and that i can get out of work a bit earlier.
If its tuned right it should be fine! Mine is a pretty good example of that :P
R34 vs R33 motor, is like comparing Miranda Kerr & Orlando Bloom vs. Miranda Kerr & Kerry Packer
That bloody M5!!
Why did you have to do beginner for Jan??
Get this white nugget to the track
That bloody M5!!
Lol watched the video and NOOOOWWWW it makes sense lol.... Farken M5 was a clown and the ute thought it was powercruise lol
White nugget is coming soon!
No spots for the other group
Booked the same for both, i assume that is what you did? lol... If not ill just be super newb anyway!
Engine is back in and running -
1520804_10152064063375690_1713892091_n_z
the black 33 is looking sexy with those wheels, should of moved that red trolley out the way, oh and the white 34 is ok I guess :P Edited by AngryRB
I'll see you two for the Feb twilight day
Awesome! Ill be looking forward to that :D
Sonfa.... :P
Nice bonnet dampers :ninja:
:yes: indeed!
I'll bring a lap timer for you to use in a session lol
Awesome! Will be interesting to see :D Ill see what i can do to arrange one for the Jan session too so i can see if i can improve lol
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
