Just finished reading this thread. Absolutely love your car, Love the stock look. May become the path for my 34 when its in my hands. What exhaust are you running?
Nice work! I have the Apexi system (Super Megaphone II i think)... Its so quiet its not funny yet still flows big power :yes:
Epic car Mattty love it! Good to see a fast RWD car that wasn't built just for da straight lines bro! :yes:
Thanks Mick_o..... It was always meant to be an all rounder, not particularily good in any one field, just able to have fun in as many as possible! I want to do more track and hill climb this year so will probably give things like Texi a miss to save stressing the poor thing out haha....
Hows your beast coming along?
Oi you still coming on the 26th
Yeah ill still try make it down, will see what happens with the cooling system i guess :)
The beasts going well thanks Matty just waiting for FP taking their sweet ass time with my 73 HTA been almost 3 months now :verymad:
Hoping the budget will permit me doing a few hillclimbs and track days myself... The bug bit on hard after my 1st track day at SMSP south circuit last year.
Looking forward to seeing you out there again soon :yes:
Strange, they had mine too me in a week :O They were damn quick....
And yep i know what you mean about the track days, this year will be plenty of track time i hope! A few things on the calender already :yes:
Hopefully we can catch up at an event soon!
Anything exciting to report? Or is your car broke again? :P
Basterd :domokun: lol
Its jacked up just getting some work done before next Wednesday... Will see how it goes :whistling:
Will be plenty to update on as the year progresses! :yes:
  • Like 1
Track day!!! See you there
Want to follow for lines??
Ill be there ;)
Will be doing some tuning etc while on track so will be looking for some open space... Once done then yeah ill probably come play!
Lap times!
You need to beat the red turd tractor!
Lolz, if i get it to finish a session without breaking something then its a successful day, not that worried about times yet! Reliability is the issue i have!
oi, come HSV track day, 23rd March.. come chop bogandores
Ill see how i go as i have a fair bit on in March! Its tempting though!
So due to the smaller shed i decided to go to Super Fail and grab some Go Jack thingos... They are brilliant and it was basically buy one get one free! So i gave them a trial and they work awesome :woot:
First time the car has been sideways and actually under control :rofl2:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
