For the not so good news, the brilliant bonnet struts i fitted have been working well but i use the bonnet quite a lot unlike the others i guess and it has created a weak point in the bonnet and it has now effectively collapsed... Its dissapointing as the bonnet was repainted and looked pretty good up until now -
I guess this was just a freak failure and i dont think there is anything wrong with the actual product.... They are a good price and worked well, maybe too much use :(
I wouldn't bother with the temps at the hillclimb. You're not going to get them warm enough to gather decent data, and by the time you make it back to the staging area, they are going to be cooled of any heat you did make. Did he show you how to take temps?
Nope there will be no temps taken at this event! No point and i dont have the gear as yet....
Yes he showed Carmen how to do it as she is in charge ;) Gotta get a proper pyrometer etc
Anyway, representing SAU at the Nulon Nationals means time for some Nulon oils -
Corporate-Logo-black-background_zpscc39a
Gearbox was a bit grubby as usual... Am going to have to mod the breathers before the next track day as both the gearbox and diff are pushing their love juices out all over the place :no:
Mat, that's generally an indicator that the gas struts are carrying too much pressure for their allocated task.
Bonnet struts don't need a great deal of pressure in them; otherwise they basically become a load point like yours have done.
This kind of damage is super common on Alloy, Fibreglass & Carbon Bonnets.
The Strut re-gas guys can set strut pressure to suit particular appilcation; this will prevent a repeat performance.
I've had hatch struts gassed at a higher pressure to allow for a rear wing before.
I think this guy will be the closest to you? They are mobile; so they come to you.
Strut Re-gas Hunter
Arie Oosterveen
Cnr Church & Foundry St
Wickam NSW 2293
Ph: 02 4961 3255
  • Like 1
Yeah that was my guess, good info mate!
Not sure if i can salvage the bonnet and just keep it for now until the car becomes more track based down the track! I want to keep the nice stock look if i can!
thanks for that. am going carbon bonnet soon and was going to use my current struts. you might have just saved me an expensive bonnet! thank you.
Bugger about the bonnet Mat, I sure hope the struts don't kill mine.
Will be interesting to see what you think of the Nulons too.
I have been using them for the whole time I've had the 33 and the 31 now is primarily Nulon filled too.
No complaints here, improvements more than anything. :D
This is your friendly reminder.
Pletty Prease.
Lol sonofabitch! I just saw this friendly reminder... The next event is at Wakefield and i assume you WILL be coming to watch ;) Then you can grab some while you are there...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
