34Geeteetee Daily / Track Project
hmm i have some camber on mine not sure how much, not much but a portion of the tyre is not in contact with the road, after driving on dirt you can see this. Kinda sucks, might have to pump the guards for zero camber get full contact.
295 on a 10 +38 with nearly 3 deg camber slightly pokes, for those wondering :D
10588654_814795625218233_842044625_n1_zp
Nice! Only problem is proper Semis will be a lot wider from what i can tell... 275 street tyres fit with plenty of space but a 265 in a semi is nearly contacting both sides as its much wider... That and -3 degrees wouldnt help much with traction so it kind of defeats the purpose of going to a wider tyre ;)
Mat, how much camber are you running?
In the front... Fk all! As i havent fit the camber arms yet, hence why the front tyres were nice and toasty on the outer edges on the left side at Wakie and cold in the inside.
On the rear, i think its back to rough -1.5 or somewhere near it as i had the track day to do. I had them down to -0.5 at one stage.
Love this car Matt, looks so basic and then it cracks gate haha
Thanks mate! Its a lot of fun...
Can't really say it looks so basic now with the cage back in
Safety first ;)
The stock look was a bit of fun for a while :ph34r:
  • 1 month later...
So i havent really done any updates in a while, basically because not much has happened... Since Wakie the car was unused and just sitting around... With all the talk of trackday prep i thought i best do some myself... SO i charged the battery... Prep complete :P
I went into the SMSP South day knowing the left side tyres were pretty banged up on the outer edge and also the alignment took a fair hit at Wakie when i had the offroad excursion, i drove it down the street and it was left hand down and pulling left... With SMSP Sth being a short track and just a fun day i wasnt to stressed and just ran it as is.
The one thing i took from this track day was that SAU NSW are a fkn top bunch of blokes! It had to be one of the best track days yet in terms of having fun.
626ca974-9786-4f81-b2bc-fe4456548049_zps
The wheels just have black plastidip on them to cover the crazy gutterrash from Wakie... It looked pretty messy so as a temporary measure i coated them with the black. Of course we had to do the white writing on the tyres to match -
This pic actually shows some of the tyre damage on the outer edge...
With the lack of camber in the front it was just melting that damaged section...
Here is what the wheels looked like after a quick coat of plastidip...
What's with the headlight?
Headlights looks maad! The left one is open for intake yes?
Loving the car man!
Yeah one of the eyelids on my proper set of headlights got broken and looks really bad so i figured i would take them out and do the lense restore and replace the eyelids... The black set is just a set of empty shells of a GTR and was mainly for something different :P
Mad. I couldn't tell in the pic if they were just tinted or something. Looks the goods.
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
