Hi Guys,
I got pulled over by Vic Roads Police today and they defected my car for having HID Xenon headlight as well as both air pod filter and fmic. They said the headlight is not stock and is illegal.
I wondered if this is illegal and how can i get my stock HID Xenon Headlight legal on my R34 GTT? Any help is appreciated and i need to clear the defects in 7 days.. wth...
https://www.sau.com.au/forums/topic/358455-r34-xenon-hid-headlight-illegal/
Hi Guys,
i believe that they are illegal and are sposed to be removed when the vehichle is complied, unless it is privately imported in which case they leave them in, but they are still illegal. someone please correct me if im wrong though
but my car still has them and i know alot of people on here still have them... the amount of cars running around with hid ect. you mustve been pretty unlucky to get busted for it :down:
exactly~ i wondered how can i get it fixed in order to clear the defects~ damm~
HID's are illegal if you do not have headlight washers. This is a defectable offence as dust particles can deflect the light onto the oncoming drivers.
If you want less attention, go for a 5000-6000k (white) range. As the boys in blue do target blue headlights more. :)
Good luck.
Shouldn't be illegal as they are factory
(on GTRs at least... Were they a option on GTTs from Nissan?)
BMWs, mercs, etc have HIDs standard & they are legal.
Not true.
There are a bunch of legislations in Australia for HID's to be legal when brought out from factory.
Most modern cars meet the legislations (as has been said, washers for the headlight, auto leveling etc). Unfortunately most Jap cars from the 90's don't meet those legislations and hence why they are removed when imported. R34's, S15's, R33 S3 GTR's etc.
To actually get fined for it though is pretty rare.
Not true.
V35 included. :(
Good luck.
Haha, and water doesn't deflect/scatter light? I live in Melbourne where it rains all the time so that should be fine anyway... :teehee:
They are supposed to be self levelling to be legal also, mine are one step better having a manual height adjustment on the dash.
It really is a joke the stupid rules Vicroads make up, If I modify my lights it is illegal but if some compliance joint stuffs them up by fitting adapters and halogen crap bulbs with weird scatter patterns its somehow better? :no:
Pretty much whatever said.
It's illegal because it doesn't level the lights by itself.
Yes, although it's factory, but if factory items doesn't comply with Aus rules, they'd have to come out during compliance.
It is also rare to get dicked for them, especially by vic roads lol.
But to answer your question, there are no way to make them legal. That's why compliance converts them to H1 globes.
If you want, for a bit of money, I can reconvert mine back to H1 and lend it to you to clear your defect. Also have a stock airbox too.
were there any xenon lights that were legal? only reason i ask is when i got pulled over it was because of my lights saying there hid lights i told him they were the lights that come with the car had to pop bonnet and he got in with his torch (it was 2am)and looked behind the lights and after looking was like righto that's ok then went on to epa me lol
pm sent
Lol, it's hard to get pulled over BECAUSE of them... Most of the time that people get done is when they are already pulled over and cops just have nothing else on you, so they pick on your lights lol.
Guest
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
