Hi guys,
I have a R33 S1.5 RB25DET Manual that's giving me some grief trying to get the car running going. I bought it at auction and when I got it home I found that the ECU had been chopped out. After 3 looms I now have one that works.
I have checked:
  • Diags. It gives me a Code 11. CAS
  • Replaced CAS (tried 2 more), reset codes, check and get 55. All ok. Then crank and still get CAS code again
  • No Spark
  • Cant hear injectors pulsing when turning the CAS by hand
  • It has Fuel pressure
  • CAS has Power at plug
  • Coils have Power at plugs
  • Everything is plugged in besides ABS Unit plugs (Series 1.5 with Series 2 loom) and one down near the ECU. Pics here
  • Cranks over fine
Does anyone know what else to check?
Cheers,
Phil
https://www.sau.com.au/forums/topic/358464-no-spark/
Pull the plug off the ecu and cas. Check continuity at each end for each wire (at ecu pin out and at cas plug) by using a wiring diagram. then check for short to ground with each wire. Are the coils being switched? doesn't sound like coils or injectors would be pulsing if no signal from cas. If loom test up ok, and you have tried 3 cas' then it has to be ecu.
https://www.sau.com.au/forums/topic/358464-no-spark/#findComment-5734945
I was told it is a Series 2 Manual Turbo ECU. Ill get the part number off it tonight.
And Ill try those suggestions. Ill try and find part number on the ECU to Engine Loom too.
It cranks so I would assume its not the Auto Neutral safety switch. Ill double check anyway.
https://www.sau.com.au/forums/topic/358464-no-spark/#findComment-5737965
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
