Hi guys and gals, so I have built a new forged RB26, with 270 10.8mm tomei cams and a 70mm billet turbo (slightly bigger than a t04Z), problem is its very laggy, it starts to make boost around 3500 1-2 psi but takes till about 5700 to get up to even 8-9 psi and then full boost of 19 at about 6500. I have adjustable cam gears and want some info on how advancing or retarding inlet/exhaust mght help my lag problem to make the car more responsive.
Im quiet aware that big turbo = lag, but this is a bit frustrating.
I had an rb30 with t04z and it would not come on boost with your foot on the brake and flat out on the gas standing still. We went drag racing and it ran a 13.6, spoke to a guy in the pits who said to roll the cam 1 whole tooth to advance the cam timing, next pass was an 11.1!!! It came on boost at least 1000 rpm earlier!
So just want to know if it might work the same way with this engine. Any opinions would be appreciated..
Thanks Christian
https://www.sau.com.au/forums/topic/358466-cam-gear-adjustment-to-reduce-lag/
You will make - some - more torque down low adjusting the cam gears, however its like pissing in the ocean to top it up. You might change the level, but you wont really notice it. Your turbo to engine to tune match is wrong, simple as that :action-smiley-069:
But in a freezing Southern ocean it can really help to warm the inside of your wetsuit, or so I hear.
I'd rather a healthy area under the curve at the expensive of peak power than visaversa, both at the same time would be nice but you can't have it all, unless you go to extremes. I dropped exhaust housing size to gain response and mid range and never looked back.
it amazes me that we need to retard and advance valve timing that much on an RB to get a better deal in the performance stakes down low..........bit like robbing Peter to pay Paul.
Nissan clearly had no idea what they were doing when they structured the RB's valve timing :/
Why such a big "f off" turbo mate? Why not go with something slightly smaller to get good value out of the built RB26??
Im building a spool stroked 3.4 liter motor next, just wanted to spend some time doing the new motor so I built this one to fill in the time..Im sure i'll have no problem selling it when the new motor is ready to go.
Im quiet aware of the lag issue with a big turbo, just wanting to know of peoples experience with varing the cam timing to counter act somewhat the large frame turbo hence the tread in the first place.
Its running a .81 exhaust housing, 4 inch dump, and 3 inch exhaust but the exhaust will be upgraded very soon to 4" all the way.
Don't get me wrong its great fun to drive but just wanted to get the spool time down as low a is possible with the 26 capacity motor.
Thanks for your feedback everyone
Edited by chrisking666
retarded to -4 is generally the consensus for Rb26 exhaust cam gear setting
not too sure on the intake, advanced to +1 or +2 ?
I was thnking the same thimg myself, I have retarded the exhaust cam 4 deg and it has definatly made it come on earlier prob 500-700 rpm earlier with no sign of falling over in the top end.
Im waiting for the adjustable inlet cam gear to arrive, I ordered 2 and only one turned up! pain in the arse really but when it gets here i'll advance the inlet 2 deg and see what happens.
Cheers Christian
a shot of nos low in the rev range would get the turbo spooling faster. or something as simple as a smaller intercooler so there is less volume to be pressureised by the turbo. i binned my omg look at me whale baleen cooler and put on a smaller unit, still get same power but less lag.
something like >>>THIS<<< could help improve the effectiveness of the cooler.
Thats what I'm trying to do, save buying 2sets of turbs's I'm going be running the gtrs's on the 26 with a small ARC 70mm twin entry cooler with cam gears and see how I go. I know it's gonna be laggy as Fu*k but time will tell.
If your mind is set on that particular setup, go and see Martin, get the thing tuned for Hoon Juice, then not only will you be able to throw a bunch of valve & ignitition timing at it but extra boost too.
That'll help with what you're looking for.......plus a few extra killawasps which can never go astray.
Krishy even has a cigarette hanging out of his mouth whilst pouring the stuff into his tank :yes:
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
