Wanting To Swap My R34 Gtt For Cheaper Car + Cash
Jay11
 Share
  • Replies 45
Yeah I'm surprised it hasn't gone either.
only two ppl have come to look at it and both have wanted to buy it and both finances have fallen through :(
Gah couldn't happen at a worse time with all the wedding payments due.
I'll even consider taking just $7k now and get the rest in a month or two!
Had a guy messaging me telling me that he's seen heaps of 34 gtt two door manuals for $9k. Load of crap!
Edited by Jay11
Very last price drop!
$10,999
Get it before somebody else does.
Whoever buys it is getting an insane bargain!
Losing money on this baby selling it this low but it's gotta go :(
If anyone is unsure about this car please just come check it out before you judge why it's going so cheap, yeah it does have higher k's,
but there are a few guys on here that go to the brissy meet that can vouch for this car for an unbiased opinion :)
Edited by Jay11
Dude I know how you feel about the wedding thing (getting married in August myself) and luckily the g.f wants to use my car as her wedding car so maybe its time you did some convincing to yours :P.
Oh also free bump to the cheapest 34 GT-T I have ever seen, God I wish I had money.
Haha lucky man!
It's funny you say that coz seems to be that every guy that calls me up tells me they have seen heaps for $9000 and that mine is too expensive! ( I've never seen an R34 GTT 2 door manual that cheap, ever)
Just today I had a guy call me up and said he "use" to work for an importer and he was telling me that he knows what they're worth.
He said they tried selling them for $15k but usually got around $12k.
Biggest load of crap I've ever heard, I have never seen an importer or yard have one for less than $18k, if it were less then it would be a heap of poo!
He asked if I was negotiable, so I told him I've dropped it from $15,000 to $11,000 thats negotiable enough.
And that was the end of hearing from him :)
You should buy it! Wish there were buyers like you!
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
