What kind of bodykit you got?
Just not fair. :(
Do we even get paid more than people in USA? :rant:
I think its a factory kit with front lip, side skirts and rear spoiler. Ive seen others on my37.com with the same one.
I just got back from the states and everything is cheaper, however average wage would be lower. The only item I can think of that was similar to Aus was the iPad.
Shoes I bought were 50% cheaper. laptops, cameras, cam-corders (which I also purchased) approx 40% less.
Going to the movies on a normal night is $10.
The one thing that got me the most was paying for the road toll from Ft Lauderdale to Miami Florida. Im use to paying $3-$5 in sydney..........over there $0.25 cents. And let me say their 6 lane highways (in each direction) shit all over the M2, M4, M5 etc.
Just on the side. Ive had the battery disconnected for 3 months, and definitely there was an improvement in throttle response etc with the ecu reset. It felt very quick. Even the response from the paddles was slightly better.
Nice. :)
Yeah, I guessed you enjoyed your trip to the states then with everything so cheap. :P
Nice. :)
Yes, but the key difference is that even after 3 months his Skyline is still were it was. In the States it would be 'hey, didn't I park my car here? Oh %@#$!!" Or, as a minimum, someone would have taken tenancy, and it'd be full of cats...
$80-$90k is a good estimate. remember that the v35s were somewhere near that price when new and im pretty sure so are the v36s (g37) etc in japan. also comparing prices to the states and our aussie dollar, doesnt matter if our $ is higher to U.S cars tend to be more cheaper for them, but keep in mind their living standards are cheaper then ours so $30k+ in there terms is a lot of money.
guess we'll have to see if price will head northwards or maybe depreciate very slowly. thats if we survive pass 2012 =)
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
