  • Replies 804
if you mean J_R32 (this nick) then we no longer have 32's. (my bro uses the same account)
we DID used to have r32 sedans. yes siblings having the same car...lol
So I've got
EXEMPT
LoneWolf (dope)
Wogan
Boss-Zilla
PewPew
Ten-Four
-Jimmy-
gazza750
turboedsloth
bubba
ohno1
J_32
R32 GTS4 4 Door
kingscorp
94GTR32
15 R32s and counting. Considering Perth has over 2 million people...you'd need a few more than 15 to be classed as common!
I once said Stae-Ge-a
LOL yeah I've said
Stag-eeya
Staj-eeya
Staj-ah
Stay-jeeya
Stay-geeya
Undoubtedly one of the most confusing Nissans out haha.
But then Pagani just take it to the next level with the...wait for it....Huayra! WTF!
EXEMPT
LoneWolf (dope)
Wogan
Boss-Zilla
PewPew
Ten-Four
-Jimmy-
gazza750
turboedsloth
bubba
ohno1
R32 GTS4 4 Door
kingscorp
94GTR32
tut tut...DELETED! :thumbsup:
Yeh, I've given up on it.
I just call it a stag now.
The only bad thing is, old people sometimes join the convo and think we're talking about some old Triumph...
It is truly annoying name LOL
What were having done in xspeed the other day? Caught a glimpse of your plates when I picked my car up haha
Edited by EXEMPT
Tune... a rather expensive one..
No shit. I'm up for 1200 when my HKS EVC and tune goes down in two weeks.
Spent 660 there getting my overboosting issue sorted. Turned out my EBC had shorted out inside and was dead and my actuator was f**ked. Lot of diagnosis and stuff.
Made 276hp on 16psi without an boost controller so im content at least haha.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
