*sigh* ok, I'll save that for the next SAUWA Paintball day :P
Got the bottom end up to the workshop this arvo, will get up there next on Saturday.
Missed the courier that came to drop off my new radiator :(
Got confirmation clutch left yesterday :banana:
  • Replies 804
32 is booked for the painters, finally some slow progress. She's getting this colour http://imageshack.us/photo/my-images/59/2005yzfr1lavaredjpg.jpg/sr=1
Edited by turboedsloth
Not for ages i don't think. Hopefully end of the year. It's an on going project thats been 2yrs so far. Slowly buying engine parts and suspension goodies atm. Nissan Japan just finished remaking my door seals which took 3 months to get
Nice colour Corey!
Pulled the turbo off the wagon yesterday arvo.. looks like a pretty big highflow (it's unknown and came with the car), there's only a couple of mm of snout left.. keen to see how it goes on the 3L :D
the only thing i dont like about the 4 doors (this goes for 32/3/4) is the tail lights. If it was easy to put the coupe ones in i would go for it. I understand that Nissan wanted them to be different but they just look like @ss to me.
Got my clutch yesterday :thumbsup:
Sent turbo off for inspection and possible rebuild (leaking a bit of oil), on the plus side I may have found who built this unknown highflow!
Handbrake shoes being collected today and hopefully injectors.
Went to wire in my resistor box and new injector +ve's and was left scratching my head over WHY the standard loom is laid out the way it is.. (injs 1,2,3 on main part of loom, injs 4,5,6 on sub loom that bends back on itself) seems rather pointless so I've traced back the injector earths and the common feed all the way back to near where the igniter plugs are. Not running the IACV so can actually piss off the whole front sub-harness.
Going to Jaycar today to grab some more wire and will run all the injectors earths through the new loom I've made and my mate is bringing round a nice sealed plug so that the whole injector loom will be removable.
I think it's purely for spatial reasons, it's pretty cluttered under the standard plenum what with TPS plugs and IACV plugs in the same area. The only thing that is subject to noise is the CAS but that runs in its' own heavily shielded cable.
My way will be a lot neater with the loom hidden under the plenum.
I'm already excited for it :)
Imports and bbq.
2 great things.
Going to ditch the cable ties this weekend hopefully and secure the front lip properly.
On another note. Welding internal gates (I think that's what it's called) is it a bad thing?
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
