It's a bit of a mission to rip all the lines and the solenoid out, I put a lockbar in and then waited until I next had the engine out to remove the rest of the crap.
I got my lockbar off a trader over east (NYTSKY).
  • Replies 804
pfftt, did mine with the motor in dont be weak. I know i did it when the rear cradle came out so cant remember how hard it will be with it in.
Rear cradle in or out make no difference to complexity. It's the solenoid under the plenum and the lines across the front crossmember and the cooler line that runs across the radiator support that present the problem.
I must say, it's a lot easier to change oil filters with the solenoid gone :P
I also ran an oil cooler in line with mine after i pulled the hicas out, there was another trader selling lockbars to but i havent seen him around for ages.
Once you pull the hicas out use the steel lines as "upgraded" fuel lines, they are 1/2in i'm pretty sure
Yeah i'm definitely not going to the amount of effort as taking all the tubing out.
Bare minimum is what I'm prepared to put in, the lines can stay, they won't be harming anyone.
Need to replace the front drivers side tie-rod end at the same time though, what is doing one of them like? No experience in suspension unfortunately.
Haven't had much of a chance to drive her around in the dry yet, but the other night I did and boy is the back end slippery on boost.
270hp really creeps up on you good when you are used to an auto ford BA :P
i fit mine next to the drivers side head light, but then again i had no air con core either. I miss that POS. :(
Worst comes to worst I'll mount the p/s and oil cooler at the top in front of the radiator but was trying to keep that path clear. With the GTR cooler setup behind a stock type-m front bar, doesn't leave a lot of room for anything!
But really I'm not phased at the moment, it's only going to be a daily until I get a gearbox for the wagon.
another trick i have seen (as it is not a super critical thing) is the cooler mounted at the base of the rad with a small scoop picking up air from underneath.
If you were looking between the rad and motor you would see it sitting horizontaly below, bit hard to explain.
That is one of the potential locations :thumbsup: another is in between radiator and cooler (directly above bov return pipe), right down the bottom with a long narrow core, something like this should more than suffice.. http://www.summitracing.com/parts/DER-13210/?rtype=10
What turbo is it? Looks like a highflow?!?
It's the highflow off the wagon but freshly rebuilt by Grant at Per4manz (he built it originally), reckons it's good for 24psi and 400rwhp but I'll probably only wind 15psi into it until I get a new gearbox for the wagon.
    • interestingly enough, i found out the answer is yes. doing a flush did fix my recurring A/T light. it might have been because of the trans filter: but that doesn't really make sense to me. the fluid/filter was super dirty. would that increase the pressure in the lines and trigger an A/T light? does the car even have a way of detecting that? i have no idea. i've done 200+ miles after the flush and no A/T light. if my A/B solenoids went bad, i would think the light would've come on. shifts and drives way better now though...at 2k rpm instead of 2500...no hesitation and downshifts when i want it to.
    • I vote go red. Only because I hate keeping gloss black clean. Was no worries helping out either! Glad you've survived the rain outs of QLD
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
