  • Replies 804
Might just ring the machinist I used to work with and see if he will knock something up, not hard I just don't have the tools to do it :(
26 covers would work but it's $_$ I don't want to spend right now and it would means pulling the cam gears off to get the RB20 backing plate off which I really cbf doing :P
Some of the machines are bigger than my shed, bbbuuuuuuuutttttttt after the hoist comes a lathe. Have been looking out for one, gota pay a visit to Hare and Forbes and Ron Mack i think. Some of the companies down here still don't give a f**k to making special parts so i'll do it "in shed-house" :nyaanyaa:
Ahh the R32 All Engines manual :P
I've got a 32 GTR workshop manual too which helps with a lot of the body/chassis/electrical stuff, it's GTR specific but GTSt is close enough in most aspects.
has it got wiring diagrams?
needa find the positive and negative for the fuel pump and cbf pulling out
Bloody bigassed radiator makes the shroud not quite fit the fan :/
I fit a 52mm radiator into mine. Had to buy the thinnest thermofans on the market. Flex-a-lite
Powersteering line got in the way, had to make custom line and bend it off to the left.
I've had a 50mm radiator in there before but the tanks weren't this big, I'm going to move it on and go something more stock sized. I have two thermo fans on the front of the radiator but most definitely want to retain the engine fan and shroud.
yeah the cheapest option.
Tried to say some coin by buying a cheap radiator but got dudded for not fitting. Spent $500~ on thermofans and controller to make it all work haha
However, whilst crusing & spirited driving, water temps stay on 78degrees.
When come to a stop, thermofans programmed to start 1 fan at 50% when 82degrees. Doesnt move unless im stuck in traffic for ages. Might crawl up to 85degrees~. When reaches 89degrees, both fans turn on at 100% to bring it back down to 80degrees.
Nice setup, what controller are you using?
with the 30det i have 52mm rad with the standard clutch fan plenty of room ovaboost were meant to use the twin thermo's i gave them but i guess they cbf and as most ppl will tell u the clutch fan is better than thermo's
Edited by Char
Mick would have done it for a reason. I had thermos in my 32 and we pulled them out when Mick was dynoing it, the clutch fan was way for efficient and cooled better than the thermos for some reason
That's why I want to keep the engine fan, the thermos on the front are just added insurance.
Char, pics please. This 52mm radiator I have would be fine if it didn't have tanks the size of Texas FFS! The tanks actually make it more like 70-75mm and it's way too close to the fan for my liking.
Anyone wanna buy it? probably fit in an S13 very nicely or a 32 without an engine fan :P
    • Hi All Does anyone know what size bolts are used to mount the bonnet hinge to the bonnet on an R32 GTR please? I'd usually just buy them OEM but they are nearly £20 each and I need all 4
    • interestingly enough, i found out the answer is yes. doing a flush did fix my recurring A/T light. it might have been because of the trans filter: but that doesn't really make sense to me. the fluid/filter was super dirty. would that increase the pressure in the lines and trigger an A/T light? does the car even have a way of detecting that? i have no idea. i've done 200+ miles after the flush and no A/T light. if my A/B solenoids went bad, i would think the light would've come on. shifts and drives way better now though...at 2k rpm instead of 2500...no hesitation and downshifts when i want it to.
    • I vote go red. Only because I hate keeping gloss black clean. Was no worries helping out either! Glad you've survived the rain outs of QLD
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
