  • Replies 804
:unsure: , i haven't had my 20 for a while, but from memory they should all stick the same amount out when you sit them in the holes. You can't really mess them up i think as they will bottom out, but seeing as you engine is in you might not be able to see properly
Sussed it I think, there are a couple which will only have about 10mm of thread engaged but most are between 15-20mm and I checked the long ones in the head to see how far they will go in before bottoming out :thumbsup:
Sweet, i'm still hunting down bits and pieces for my engine. Am changing builders for the engine, mate had some things happen that havent really impressed me with that workshop. Gona go back to old faithful i think
My very first car, bought with the money i've been saving. I think it's a pretty good car to learn on since i'm 17 haha :D, new front mount and boost gauge going in at the end of the month. :)
Looks nice, needs moar pics
Tidy! If anyone wants a searchable pdf copy of the 32 gtr workshop manual.. you can find it at the following link for a few days (until I need the space back :) ).
http://members.iinet.net.au/~psyko/car/gtr_32_service_manual_searchable.pdf
RB 20 engines make me angry. Made for Japanese people with small hands :(
Bah ridonkulous! Once you pull half the shit out of the bay you don't need and go high mount, you have enough room in there to dance around
I had 310hp with boost spike, unopened motor, gtr inj, ems and 6boobs mani, lasted 5yrs before i pulled it out for teh restoration. The 25 conversion is up to you really if you feel like you wana go that way. My old turbo setup is going onto a 25 in a 31. I was going to go down a stroked 25 route but changed my mind for the 26/30 which would have cost the same.
The 20 is a great base to play with they just love to rev
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
