If anyone needs odds and bods for their 32 i'm stripping a 4 door atm for the interior. Theres no suspension components but i have front quarters, reo, abs unit and little bits. Or if you'd like the shell with some LHR damage come take it
Bah! why couldn't it have been a 2dr :P
  • Replies 804
thanks guys fresh forged motor going in as i speak !! take a look...
sard 700 cc injectors
brand new garret 2860-5 turbos with all new gaskets
hks exhaust gasket and tomei metal intake gaskets/throttle bodies
acl race series full engine bearing kit, along with king bearings unknown what they were for !
shim head gaskit race series (metal)
N1 water pump
tomei UMEDA oil pump
tomei 260 deg cams
custom built extended sump and pickup with trap door setup in sump (MADE BY RED R RACING )
rebuilt front diff and preload reset
engine balance
machine crankshaft
ross harmonic balencer
cp forged pistons, 30thou over size from original bore
eagle conrods
gates performace timing kit
replace crankshaft oil galleries with screw in plugs
deck block
recon head ,full set of valve guides,3 angle valve cut ,set of shim tappets to cams supplied
aftermarket valve springs
custom work (drill and weld up oil galleries in head advised by red r racing)
TOMIE Oil Feed Restrictors
TOMIE Sump Baffles
HKS Adjustable Cam Gears
ARP Mains + Head Studs
All New Hoses And Gaskets
Oil Relocation Kit + Cooler
alloy Radiator
new clutch built by (JIM BERRY RACE CLUTCHES QLD)
Nismo Airflow Meters
New O2 Sensors
trust 600x300x120mm Intercooler,
recent full rebuild on gearbox
running the nistune ecu with nismo afms
and a blitz i colour elect boost controller
    • I vote go red. Only because I hate keeping gloss black clean. Was no worries helping out either! Glad you've survived the rain outs of QLD
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
