It's a bit of a mission to rip all the lines and the solenoid out, I put a lockbar in and then waited until I next had the engine out to remove the rest of the crap.
I got my lockbar off a trader over east (NYTSKY).
  • Replies 804
pfftt, did mine with the motor in dont be weak. I know i did it when the rear cradle came out so cant remember how hard it will be with it in.
Rear cradle in or out make no difference to complexity. It's the solenoid under the plenum and the lines across the front crossmember and the cooler line that runs across the radiator support that present the problem.
I must say, it's a lot easier to change oil filters with the solenoid gone :P
I also ran an oil cooler in line with mine after i pulled the hicas out, there was another trader selling lockbars to but i havent seen him around for ages.
Once you pull the hicas out use the steel lines as "upgraded" fuel lines, they are 1/2in i'm pretty sure
Yeah i'm definitely not going to the amount of effort as taking all the tubing out.
Bare minimum is what I'm prepared to put in, the lines can stay, they won't be harming anyone.
Need to replace the front drivers side tie-rod end at the same time though, what is doing one of them like? No experience in suspension unfortunately.
Haven't had much of a chance to drive her around in the dry yet, but the other night I did and boy is the back end slippery on boost.
270hp really creeps up on you good when you are used to an auto ford BA :P
i fit mine next to the drivers side head light, but then again i had no air con core either. I miss that POS. :(
Worst comes to worst I'll mount the p/s and oil cooler at the top in front of the radiator but was trying to keep that path clear. With the GTR cooler setup behind a stock type-m front bar, doesn't leave a lot of room for anything!
But really I'm not phased at the moment, it's only going to be a daily until I get a gearbox for the wagon.
another trick i have seen (as it is not a super critical thing) is the cooler mounted at the base of the rad with a small scoop picking up air from underneath.
If you were looking between the rad and motor you would see it sitting horizontaly below, bit hard to explain.
That is one of the potential locations :thumbsup: another is in between radiator and cooler (directly above bov return pipe), right down the bottom with a long narrow core, something like this should more than suffice.. http://www.summitracing.com/parts/DER-13210/?rtype=10
What turbo is it? Looks like a highflow?!?
It's the highflow off the wagon but freshly rebuilt by Grant at Per4manz (he built it originally), reckons it's good for 24psi and 400rwhp but I'll probably only wind 15psi into it until I get a new gearbox for the wagon.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
