  • Replies 804
Ahk, previous owner did the conversion on my car and I got pinged at the pits for the crossmember not bolting up to all 4 holes. It sounds pretty picky but I'd like to fix it anyway regardless of the defect. Just learning now about all the RB crossmembers (A, B and C) and S13 crossmembers as well (also A, B and C).
I have done some research and looks like most people say an SR20 manual crossmember (labeled 'C') fits.
I think when my conversion was done the auto crossmember was used and had flat bar welded to it so all 4 bolts were used
Pretty much what I did for the 25 box conversion but the other way. Used 5mm flatbar to extend the RB20 manual Xmember to pick up all 4 bolts holes (25 box mounts are further back)
Yeah fabricating something to fit is the best bet but I can't weld and don't have any time to take it anywhere haha. I think I'm going to get an S13 one this afternoon and see if it fits.
I haven't quite got my head around it all... I'm not sure if there's A, B and C mounts for EACH car (Skyline and Silvia) or just those 3 mounts that universally are used on both chassis.
Here's a pic (all are facing the same way), seems like I need the top mount.
Sorry to hijack the 32 thread with completely confusing and boring content.
I have the middle one but it sits too far forward. The bottom one is a custom one.
I will go out on a limb and say you have an R32 GTSt MANUAL Xmember.. I had to extend my holes with flatbar because the mounts on the 25t box are 50mm further back than the 20t box.
If it *looked* strong enough I don't see why not..
75PFC with 5mm flatbar extensions for the holes a gusset on each leg and decent welding (read: not dodgy looking) should be fine if you wanted to make one from scratch.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
