  • Replies 71
any pics of R34 Stereo & Din Pocket Bracket - $15??
It's in the attachment mate :P
Between the picture of the steering wheel airbag and white mud guards.
Nah, I don't have a radiator. My number is 0434 502 855.
More than welcome to give me a call.
GTR door jam panel just became unsold as I realised it's the left one, not the right side one lol.
Haha, one of them is slowly losing the H pattern and I think if I spent 2-3 hours trying to fix em up with the kit, I'll probably only get $100 for them lol.
effort vs money = not worth it xD
Same as the steering wheel I guess haha
Added:
R34 GTR MFD - $600
R34 GTR Cluster - $250
R34 Right Bottom Dash - $40
R34 Din & Headunit Side Panel - $60
R34 Glove Box - $40
R34 Top Dash Vents - $15
R34 Boot Carpet With CD Stacker - $70
R34 GTR Brake & Clutch Pedals - $30
R34 GTR Right Door Jam Panel - $35
R34 GTR Headunit & Climate Control & TV - $150
R34 GTR Gear Surround & Ashtray - $180
R34 Cluster Surround - $30
R34 Center Console - $80
R34 Driver's Window Switch - $25
R34 Dash With Side Vents - $70
do you still have the C/ fibre sheets?
I do mate. A4's or I have a little bit of my roll left, maybe 2-3m.
SMS me if you are interested, 0434 502 855 :)
R34 Series 1 Standard Front Bar SOLD
R34 GTR Cluster SOLD
R34 Din & Headunit Side Panel SOLD
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
