  • Replies 68
Given that the regulations for speedometers is +/- 10% accuracy, this is incredible.
Does this reg not also apply to speed cameras and guns themselves aswell? Im sure they also have a degree of inaccuracy.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729899
I've actually heard from some one who works in the nsw gov, that all this is happening because the state is broke
Knock-on effect:- Keneally is actually doing O'Farrell a favour > to take a step towards balancing the budget.
In regard to your relevant comment Owen, O'Farrell is on record to have stated, "I want greater police presence (rather than fine people off the road)"
He wouldn't have to repeal an RTA intention as it hasn't been enacted yet.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729921
funny how the governments in sydney are the ones that are broke and struggling and rather than finding positive ways to re emberse themselves - lets say take a pay cut for instance... on there almost obscene wages. they target the easiest and slyiest way to get "quick" bucks without any real retaliation and the sucess rate is going to be massive, not just for import drivers but all drivers.
what ever happened to the give aussies are fair go slogan?
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729980
i think it would be fairly easy to torpedo this by disputing fines through court again and again.
Given that the ADR's give +/- 10% at 40kph you could argue that purely due to aus design standards that it is impossible to regulate your speed to the required standard.
The only way to ensure this (at 60kph) would be to drive a marked 6kph slower than the posted limit, with the possibility (due to above +/- error) of actually going 12 km under the limit (48 kph) and as such possibly obstructing traffic.
Win that argument a few times... job done.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729993
It is a good point, but, how many people fined with doing 61 in a 60 zone are going to opt for the legal option? I would say, and I am sure this is an assumption of the RTA/Government also that the vast majority of these people will simply pay the fines.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730011
i think if it were uncommon to be fined for that kind of offence you'd be right, but given the spike in cameras thats also planned, it would mean that being pinged for 61 would become quite common.
As the point hit is what would really hurt (i dair say the fine for 1 over would be low) i think disputes could go up.
Plus if someone gets one case dismissed based on my above suggestion, i think news would spread and it would start to snow ball.
that said... i can also see them updating the ADR's to make +/- 0% the requirement and then defecting you when you dispute it.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730033
Personally i think its the opposite
If you look at what the execs in big business get paid, and then look at government, i think the problem is that its such a low paying job for the amount of responsibility and stress, that no half intelligent person would actually even attempt it. End result is we get people in power like those we have now, from federal to state to local. No one with any actual background in running a major enterprise (which is what govt is).
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730061
unless they change the ADRs surrounding speedo readings and calibrations there is no way if you took a 61kph fine to court would it hold up
Why? Have you read the ADRs?
Everyone has been statng that it's +/-10%... But that's incorrect. The ADRs actually state a speedo has to be +10% accurate, NOT +/-
That meaning, your speedo can show your actual speed, OR upto 10% over your actual speed.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730189
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
